Question about ASUS A9RP Notebook
Printed circuit lost
I need a circuit motherboard of notebook ASUS A9RP to sent it to repair to the computershop the jack of notebook is damage i try to repair it by myself but it is not success and the printed circuit is lost. He cannot repairs it the only one to solve the problem is to find the motherboard circuit. please please help me.. thank you very much pairote lipar
    Problem Solver:
  • 11 Answers
Do you have a web cam if you do i would love to help and if you would like to chat about it email me at r.alanormerod52972@live.com
Posted on Jun 01, 2009
Asus cg1330-05 motherboard manual
If by schematic, you mean a circuit diagram with all components shown and their values, forget that. There is no such thing. Motherboards are manufacturer proprietary and they do not support independent repair. The "repair facilities" that they authorize are merely there to verify that the board is bad and to determine if the failure is warranted. Then they replace the board. Failed boards are sent back to the factory where they may be repaired or scrapped depending on amount of damage and demand of the board.
Nov 03, 2015 | ASUS Computers & Internet
My Asus get no power
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | ASUS A9RP Notebook
My laptop acer aspireone mini laptop screen is blackout i can't get it started.
You might have a faulty Liquid Crystal Display [LCD] Panel Power Inverter. Or the LCD Panel itself might be faulty. Either can be replaced. The Inverter is relatively inexpensive, a replacement LCD Panel, a little more.
To test for a faulty screen, connect your notebook to an external Desktop Monitor, using a standard VGA Cable -> press and hold the Fn key bottom left of your keyboard -> press the Function key at the top of your keyboard with the image of the two monitors on it -> release both keys -> if the image sent to the external monitor is correct then the fault is likely to be in one of the components of the LCD Screen and you should take the notebook to a repair centre to test test and replace the faulty component(s).
If you cannot start the computer at all, but there is a constant or flashing Power Light Emitting Diode [LED] on at the front but no Hard Disk Drive [HDD] LED on, then either the battery is faulty, there is a loose Direct ()Electrical) Current [DC] Jack, the Graphical Processing Unit [GPU] chip is faulty or there is a damaged Motherboard Power Management Track.
To eliminate other possible causes of the symptoms you describe, remove the battery and connect the notebook directly to the mains electricity without a battery and then try to power the notebook up. If the notebook powers up and boots into its Operating System then the battery cells are probably depleted and cannot recharge, so the battery should be tested and, if found faulty, replaced.
If the battery is not the problem, check for a loose DC Jack. If the point where the the Power Cable connects to the notebook is loose and is either in intermittent contact or not at all in contact with its solder points on the motherboard, then power might not be reaching the motherboard. Loose DC Jacks can be re-soldered or replaced if damaged.
A loose DC Jack that is in intermittent contact with the motherboard, an electrical power surge or sudden power cut or disconnection of the power cable can damage the Power Management System of the motherboard. It is sometimes possible to repair Power Management problem afflicted notebook motherboards by replacing blown capacitors and/or bypassing burnt out or damaged circuit tracks by creating new ones. Extensive damage to a motherboard might make it uneconomical to repair. Replacement motherboards are available and could be installed but when combined with the cost of labor for the overall repair the price might be prohibitively high.
A faulty GPU can have new tracks made to it, or have a damaged chip (silicon chip) surface cleaned to restore lost graphics by two different processes, Ball Graphics Array (BGA) Reflowing or BGA Re-balling. Re-balling has the longer lasting and better success rate. When the surface of the GPU is too damaged it may not be possible to repair it.
All of these motherboard repairs require a laptop repair specialist to disassemble the notebook and test, replace or repair any faulty components. These repairs can be expensive and need to be weighed up against the current value of the notebook and the cost of a new replacement notebook.
Nov 20, 2011 | Acer Aspire One PC Notebook
I have updated the BIOS flash of my ASUS A9Rp notebook up to version 230; then the BIOS updated gave me a "successfully BIOS update" message; after that the notebook hangs and did not respond to...
I have done the same update to version 230 ASUS A9RP and bricked the Notebook. Nothing worked not even the power key or the battery charging. My conclusion was that the flash is also used before powering up to load a program into the devices that read keys or charge batteries. I HAVE SOLVED the problem writing bios 280, by taking out the chip 39vf040 4MBit Flash and rewrite it in writer I have constructed for it. Chip can be taken out with a hot air device , that exists in the GSM repair shops also. A socket (~0.5 Euro) can be places in the position of the chip. If you need help I offer my assistance to guide you or even send you a written chip (~1.5 EURO) on the mail ,
Nov 20, 2010 | ASUS A9RP Notebook
Motherboard
Return it back with an explanation letter and your last reference number.
Mar 27, 2009 | ASUS Eee PC 900 Notebook
Missing asus A9RP sound card driver
HI
http://support.asus.com/download/download.aspx?SLanguage=en-us
Just go with link u can find all drivers
Harry
Dec 10, 2008 | ASUS A9RP Notebook
Removing keyboard for ASUS A9rp
There are three little clips at the very top of the keyboard itself, if you lightly push them in starting at one side while very lightly prying on the keyboard you can lift it out and then just unhook the ribbon cable. That's it, really simple actually!!!
Mar 31, 2008 | ASUS A9RP Notebook
ASUS A9RP Notebook Logo
137 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
