HI. i recommend checking the compressor for its operational value. if the compressor is not cycling at all, this will confirm compressor failuer. if it is cycling and, it is not cooling, this will confirm a low charge rate. it will need to be recharge in this case.
Comments:
May 22, 2009
- That can be a sign of a running compressor but, you will need to observe the cycle. it should come on and off in a cycle. if the cycle is rapid, this will confirm a low charge level. if the cycle is consistent and only last for 3 minutes at a time, this will confirm compressor failure. the seals are bad.
To clarify. If the compressor is running in a three minute interval and is not cooling, this compressor has failed. the internal seals have ruptured. check for any abnormal noises as well.
May 22, 2009
- Yes. the running motor has failed. you will need to replace your compressor in this case. this is the reason for the non cooling state.
My Danby wine cooler DWC283BLS does not cool and the top fan is not spinning. I switched the plug on...
(More)
My Danby wine cooler DWC283BLS does not cool and the top fan is not spinning. I switched the plug on the board for the bottom fan and the top fan and the top ran and the bottom did not. The compressor is getting hot and the cooler temps drops for a while then starts to rise. What keeps the compressor cool? Is the top fan supposed to spin all the time?
