Question about Brother HL 1440 Laser Printer
Brothers Hl 1440 memory upgrade
Where does the memory stick go?  can't find instructiuons. Jack
    Scholar:
  • 149 Answers
Assuming that you have the Brother HL-1440, your printer comes with 2MB installed. You may upgrade it up to 32MB maximum. However, your printer appears to use SIMM memory modules. The specs for the printer should be:
Speed: 60-80 nsec
Pin: 72-pin
Output: 32 or 36 bit
To install the memory:
1. Turn off the printer an dunplug the power cord from the AC outlet. Disconnect the interface cable from the printer.
2. Open the rear cover by unscrewing the two screws that secure the access cover and remove the cover.
3. When handling your SIMM modules, pay close attention to static electricity discharges, so be careful and hold the SIMM by the sides.
4. Install the SIMM into the slot at an angle, and then push it gently toward vertical alignment, it should click when it goes into place. DONT FORCE IT IN, be careful
5. Re-install the access cover and secure it with the screws.
6. Close the rear cover
7. Reconnect the interface cable, power cable and turn on the printer.
If all goes well, that should do it.
Posted on May 22, 2009
How do I clear the memory from my Brother HL-1440 printer?
Printer memory will clear if you simply unplug it from the wall. More likely, the old document was in your computer's disk, and you can control what prints from there.
Sep 11, 2014 | Brother HL-1440 Laser Printer
Looking for new printer driver for brother hl 1440 and windows 7
As per the printer manufacturer website, Brother Hl-1440 printer is not compatible with Windows 7.
http://www.brother-usa.com/Printer/ModelDisclaimer.aspx?Model=HL1440#SysReqs
However, you may download & try installing the XP drivers for the printer in Windows XP mode.
To install in compatibility mode:
1.a. Right click on the setup file of the driver.
b. Click Properties.
c. Click Compatibility tab.
d. Under compatibility mode, check mark "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 2)" from the drop down list.
e. Click Apply and then click ok.
2. a. Under "Privilege level", click "Run this program as an administrator".
b. Click apply and then click ok.
3. Install the driver successfully and restart the computer for the changes to take effect.
Jun 07, 2012 | Brother HL 1440 Laser Printer
MEMORY UPGRADE FOR BROTHER HL-1440 INSTRUCTIONS
if its a new computer follow the instruction of your printer and / or take it in to Best Buy or something
Nov 01, 2011 | Brother HL 1440 Laser Printer
Printer Won't Print
Follow the link below for what the lights on the machine mean. I know that if your alarm and data light are on it means the toner is empty, and you wont be able to print, you would need to replace the toner cartridge, please follow the link below.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000070/faq000170_012.html?reg=us&c=ca&lang=en&prod=hl1440_all
Apr 17, 2010 | Brother HL 1440 Laser Printer
How do I reset or clear the memory on HL-1440?
Please try this
There's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Please rate this answer and leave testimonial too!
Thanks
Mar 29, 2010 | Brother HL 1440 Laser Printer
Brother hl 1440 laser printer, print job stuck in que.
Try to stop the print spool and restart it. This should clear any jobs that's in your pc. As for the printer ususally if you shut it down for about 30 sec, it should clear the printer memory.
hope this helps.
Mar 27, 2009 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
