Question about Tatung P42BSKH Television
Cable connection the part that you screw the cable to on the back of the television has come out. Can this be replaced? Can I replaced this myself ordo I need a tech.
    Problem Solver:
  • 13 Answers
Yes in most cases this is an easy fix, but I suggest you take it to a tech. Televisions can sometimes hold an electrical charge even after being unplugged. For your safety, it is better to take it to a repair shop. The cost varies depending on your area of the country. Good luck.
Posted on May 22, 2009
I have a hp-f1523h flat panel monitor i need to know how to open up so i can replace the video cable
lay down face down on table,unscrew all screws in back,leave them in the back,lift the back off and replace cable
Jun 22, 2014 | HP Pavilion F1523 15" LCD Monitor
The 'out' cable got ripped off of the receiver box :(. The cable came completely out, leaving the metal adapter end cap attached to the receiver. Can I resplice this back together myself?
throw the old screw end away, it will only provide you with more headaches if you use it. Buy some coaxial connections from the store for about 3 bucks.....you cant get the wrong thing if you just bring the old end and match them up.
Cut the old cable line clean and strip about 2 inches back and install the end cap......If you dont have a "coaxial cable crimper" then get the connections that screw into the cable.....should say it on the package.....
Screw in the connector to the cable and connect it to the system and Viola good to go
GOOD LUCK AND PLEASE RATE THIS POST!!!
Apr 07, 2011 | Televison & Video
My TV turns on, but I have no sound
If your television works and you are not having any sound, first check if your volume is not on the lowest, or if the television is not on mute, if after checking and you see that its not on mute or on the lowest volume, then it simply means the sound IC of the television is bad and need to be replaced.
To replace the sound IC, you will have to get a screw driver to unscrew the screws at the back of the television, then a cup to put the screws in, then a glove to protect your hand from any kind of shock, then you unscrew the back cover of the television, and trace the wires that are at the back of the speakers to the main board they are connected to, that is the sound IC of the television and that is the board that needs to be replaced.
An alternative or temporary solution that could last you as long as you want is for you to connect the television to an amplifier, using the 3.5mm to RCA cables. connect the 3.5mm to RCA cable (it has a headphone plug on one end and 2prongs RED and WHITE on the other end) to the television, use the selector on the amplifier to select the tune you put the prongs, then you will have the sound coming off from the speakers connected to the amplifier.
Take care and good luck
I hope this is helpful
Dec 05, 2010 | Epson Livingstation LS57P2 57" Rear...
How do I get to the drivers side light bulb in a 2006 Chrysler Sebring Sedan? I have the replacement bulb and want to change it myself.
I will assume you are talking about the headlight?!
Removal
CAUTION: do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced life will result.
1) Disconnect and isolate negative battery cable.
2) Remove headlamp unit retaining screws. (bolts)
3) Remove headlamp unit to expose back of unit.
4) Disconnect wire connector from back of headlamp bulb.
5) Rotate retaining ring counterclockwise.
6) Remove retaining ring.
7) Pull headlamp bulb and remove from headlamp unit.
Installation
1) Install headlamp bulb to the headlamp unit.
2) Install headlamp bulb retaining ring.
3) Rotate retaining ring clockwise.
4) Connect wire connector to bulb.
5) Install headlamp unit.
6) Install headlamp retaining screws. (bolts)
7) Connect the battery negative cable.
More detailed info on how to get unit out.
Removal
1) Disconnect and isolate the battery negative cable.
2) Remove the two retaining screws.
3) Remove the upper fascia retainers by prying under the head of the fasteners with a flat bladed tool.
4) Remove headlamp unit from fender side first, then pull headlamp unit out.
5) Disconnect the wiring harness from the bulbs.
6) Remove the headlamp unit.
Installation
1) Connect wire harness to the bulbs.
2) Install headlamp unit.
3) Install the retaining screws.
4) Install upper fascia retainers.
5) Connect the battery negative cable.
I hope this will help you to get the light changed.
Jan 11, 2010 | 2006 Chrysler Sebring
No picture or sound/wont power up
Your mainboard is damaged, the mainboard is the one where you plug all the cables (component HDMI), it is really easy to replace, you only need to take special care with the screws.
1. remove all screws in the back.
2. unplugg all cables from mainboard.
3. remove all srews from mainboard and replace it.
4. put all screws back and then plug all cables again.
5. double check all mainboard cables are properly secured.
6. Test TV.
7. put the back cover and secure it with the screws.
8. Enjoy your TV again.
May 30, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Broke off cable connection on ssb 222a000 board
Individual components are generally not available. Contact manufacturer parts department for pc board availability
Aug 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tatung P42BSKH Television Logo
57 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
