Question about Sharp AL 1215 Black and White Copier
Sharp AL- 1540cs
Code L 1
  • Tonymanx Feb 03, 2008
    I have the same problem. I have even removed the scanner lock so there is zero interference from it. I also lubricated the bar in case there is some resistance from that.
    With mine even if the scanner lock warning light does not come on I still have sporadic problems of the scanner not moving (resulting in a blank copy).
    When the scanner does move I get a perfect copy.
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Posted on Sep 02, 2008
  • 62 Answers
It is located were the paper comes out look up you should see a clear plastic piece just take it out.If this does not fix it remove the glass lube the scanner rails.
Posted on Oct 20, 2007
  • Sharp Master
  • 1,113 Answers
Scanner Error
On this machine there is a scanner lock which you can turn by mistake which creates the scan code L1
Posted on Oct 19, 2007
  • Soulvisitor
    Soulvisitor Oct 20, 2007
    I think the scanner lock is on "ceiling" above where paper exits. slide switch to unlock, power off and on
  • Soulvisitor
    Soulvisitor Oct 21, 2007
    How about if we charge you like we do at work (about $100) for same info would that be more helpfull
3 Suggested Answers
SOURCE: Error Code "L" 0n Sharp AL 1540CS
The scanner does not move - I get an "L" code flashing on the readout - please help???
Jeri
Posted on Oct 07, 2008
  • 125 Answers
SOURCE: Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Posted on Aug 09, 2009
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL 1540 cs Code CH What is the code and how can I fix it. A new toner cartridge was installed last night.
Check the new unit is correctly seated and open and close all covers on the printer until it clears.
The CH Code is for an open cover but maybe to do with the cartridge not being seated correctly.
May 04, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Blinking h then 4
The error H and 4 blinking indicates that, You have a defective fuser unit.
H is for HEATER
You should replace youe heater unit, if your product falls in warranty period, you can avail wrranty..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Apr 10, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Jeri
Oct 04, 2008 | Sharp AL 1631 Copier
Printer drivers for Mac.
Goggle download program for Sharp AL-1540CS. This should take you to a site that will download the program for you. I recently got a new Vista computer and did this to hook up my old printer on it. It worked fine.
Good Luck
Jun 18, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL-1540cs reset for drum
Its supposed to reset itself without a service code. If it isn't let me know.
Apr 17, 2008 | Sharp AL 1215 Black and White Copier
AL-1540CS error code F5
i have al-1540cs and it if flashing H then 4
Apr 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL 1215 Black and White Copier Logo
506 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
