Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Motor will not tun over
Simplicity rear engine rider 16 HP Cornet, will not turn over.Checked the battery, It Is fine.Removed the starter and jumped with jumper cables and the starter worked.Cleaned up the battery and coil cables, but no luck.
  • 351 Answers
Check to make sure the motor turns by hand, you may want to remove the sparg plug to make it a bit easier to turn, if it turns ok you may have stripped the gear on the starter or possibly the ringear
Posted on May 22, 2009
I have a kohler 25 hp on a simplicity tractor. Turn the key nothing but I can jump across starter the engine starts then shuts itself off in about twenty seconds.new starter and switch
Sounds like you may have two issues..one electrical and one mechanical..
When you say jumping the starter, do you mean the starter solenoid? If you can jump the solenoid and the engine will start, you have a bad solenoid..
The running for twenty seconds is about how long it takes to burn the fuel out of the carb bowl.
The needle and seat need to be cleaned/replaced.. this is the valve that controls the flow of gas into the carb... if its not working properly it will do exactly as you described.. you may need to replace the needle..the seats are sometimes pressed into the carb body and cannot be removed... the needle is rubber coated at the point of contact.. it wears out so the seat does not.. sometimes if the engine has set up for extended time.. cleaning might fix it!!
Jun 06, 2017 | HP Garden
Van won'yt tun over even with a jump
TRY THE STARTER RELAY IN ELECTRIC BOX UNDER HOOD .
Jan 05, 2014 | 2008 Chevrolet Uplander
My 2004 330ci won't start, does not turn over. The battery is fine, all electrical in the car work fine, plus trying to jump car does not work & a green light is showing on the battery in the truck....
If the battery is fine, why jump it? Faulty thinking to state or think: all electrical in the car work fine. If it did the starter motor would be turning the engine over. The starter motor work on electrical...not all is fine.
check: 1) 60a starter fuse/relay. 2) voltage to starter when turning key to activate starter motor, this will rule out ignition switch or relay. 3) apply direct voltage to starter motor to detect bad starter motor.
Jul 02, 2010 | 2003 BMW 330
My 1100 just spins wont turn motor over
It sounds like the starter is not engaging to the engine. Pull the starter and have it checked. Disconnect battery first. :o)
Sep 29, 2009 | 2001 Yamaha XVS 1100 Dragstar
Non starting Jota
32 amp brand new its been on charge for about 18 hours Acid for battery was put in by a dealer all electric functions working except the starter when the starter button is pushed there is a click and I can feel movment in a solonoid in front and just above the battery (in an ally case) all nuts to starter motor removed cleaned and re tightened Fuses checked (I can only find 2) these fuses are located behind the left side of the battery in a little black cover are perhaps there more fuses which are relavent to the starter the bike is in my workshop and I cant really get a go at jumping it on my own. I did try jumping when I thought it was the battery but it wouldnt go. I thought it was due to NO charge in the battery. Try a single jump lead from the +'ve on the battery direct to the starter motor. A screwdriver across to 2 solonoid connections does the same thing but is harder to control. You need to be careful as if there is an internal short in the starter motor you can run the risk of serious burns from very large fault currents flowing. Next is the poxy short battery negative to crank case...replace with a longer one to the actual starter motor 8m/m mounting bolt ( closest 8m/m to the barrel is more neat ). Less hazerdous is to get a cheap mumtimeter and measure the voltage across the starter motor when you press the starter button some times it is just a dirty segment on the starter motor remove plugs from cylinders, load the HT leads with removed plugs, rest against engine and engage top gear. Press the starter and rotate back wheel slightly backwards ( rocking motion ) going backwards engages the jaming roller clutch to move the starter off the dirty segment if present,,,
Nov 10, 2008 | 1979 Laverda 1000 Jota
Engine won.t turn
hi can you turn engine over by hand [engine s not sezied ] and how did you test the battery and how did you test starter because if the engines not seized and you put a jump lead from your positive terminal off a good battery to a starters main terminal and it wont, turn over the starters faulty or there is no engine earth so connect the other jump lead from the negative battery teminal to the engine block and try again it will turn over if the starters good if the starter turns over with the jump leads check the small terminal on the starters wire is live when someone turns the ignition key if it is and the starter does not turn over then the soleniod on the starter is faulty if no live at small terminal then the ignition switch or starter relay are faulty best of luck yates2104546
Oct 14, 2008 | 1994 GMC Jimmy
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
161 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
