Question about Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook
Image no center in display
When I start my Toshiba Satellite 1410 S173 whith Win XP and the program is ready, the imagen fit at the left side a little in the display. How I can center the image?
Toshiba 1410 cooling fan replacement
Contact a Toshiba repair center in your area, Alternatively a computer technician will do.
DIY install, components may be found on Gumtree or e-Bay.
Take care!
damnor01
Apr 28, 2012 | Toshiba Satellite 1410-S173 Notebook
How to change RTC battery of Toshiba Satellite 1410
RTC battery is located underneath the palmrest - to the left of the touchpad - they don't usually die, as they are Lion rechargeables. Unless your Satellite 1410 is losing date and time every time it is turned off, you probably don't need to replace it. But if you need to replace it, make darn sure that you replace it with a rechargeable and nothing else.
If you need to get to it, you'll need to remove the keyboard, then the square aluminum bracket above the heatsink, then get to the bottom, remove all the F6 and F26 screws, then you must make sure to disconnect the WiFi antennas. After that, the top case (including the palmrest) will unsnap from the bottom case and you'll be able to see the RTC battery.
Aug 30, 2011 | Toshiba Satellite 1410-S173 Notebook
How to manual on replacement of cmos batter in Toshiba 1410-S173
cmos battery is present inside the motherboard...go to tosibha website and enter ur model no...der u can download the hardware mannual for the particular model
Jul 04, 2009 | Toshiba Satellite 1410-S173 Notebook
Need to replace keyboard on my Toshiba Satellite 1410-s173. How do I gain access? Which screws should be removed and which should be left alone?
The plastic strip above the keyboard - you need to remove it (start by using a small, flat screwdriver and using the Windows key as leverage). After that, it's three screws (L, middle, R), then set it upside down over the touchpad, and disconnect the cable by lifting the connectors up.
That oughta do it!
Apr 18, 2009 | Toshiba Satellite 15" Flat Panel LCD...
My display is truncated on the right side
right click on desktop, goto display settings.
You will have 2x monitors displayed.
Click on monitor 2, and look below for the tick box and click extend desktop.
This should sort it.
Had the same thing on a Tosh' TE2100
Feb 08, 2009 | Toshiba Satellite 1415-S173 Notebook
I can open my computer windows xp my computer is toshiba satellite 1415 s173
i got a toshiba 1415-s173,at a flea market.but when i turn it on,all it says is password= how do i turn it on??
Dec 19, 2008 | Toshiba Satellite 1415-S173 Notebook
Power up problem
it has nothing to do with the ram, it is the issue of the adapter or battery for toshiba laptop, if the output volatge form the adapter is not steady, the light will get yellow and blink,try it on another toshiba laptop. if it is normal, u should test the toshiba laptop battery by the multimeter, connect the electroprobes wiht the anode and cathode, if the pointer does not fixed in a short time ,the battery is the issue. change it for a new one.
Jun 27, 2008 | Toshiba Satellite 1410-S173 Notebook
Toshiba Satellite A135-S2386 Notebook (PSAD6U-01D00D) PC Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
