Question about Craftsman Garden
Motor dies when engaging the cutting blades
Also when the clutch/brake is depressed on a 17.5 hp Craftsmen riding mower with a 42 in cutting deck
  • rb49 May 22, 2009
    Check the safety switch under the seat. Disconnect it and clean the contacts. That was the problem with my mower.
    Good luck,
    RB49
I need help with this exact same problem. Someone please answer this question.
Posted on May 22, 2009
I have a craftsmen. Went out to mow and the battery was dead. Recharged it and then when i went to let off brake/ clutch it started to die. This also happened when trying to engage the blade. I check...
Just to help you with your troubleshooting:
You can get off the seat with the engine running if the blades are not engaged and the brake is on.
I also think that you can start the mower without being in the seat, but I'm not sure about that.
First, see if you can jump the seat switch.
Second, I think the discharged battery is a different issue.
Gary
Sep 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Problem still exist,engine dies when brake relesases,blade engage,unplug safety switch under the seat
Switch under seat needs to be plugged in and make sure the pto lever for the blades is depressing the safety switch. If you are sitting on seat and seat switch is plugged in properly and it cuts off when brake is released then it is seat switch. It is about a $10.00 part; no big deal to replace.
Oct 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42" 15 hp craftsmen mower dies when let clutch peddle out
have you tried fitting a bypass wire to seat switch and retest then try disconnecting it completely and retest
if that does not work check that the blade engage switch is not stuck down.
check that catcher switch is not open if this nodel uses a catcher ?
have a look ?
cheers
Sep 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When i turn the key on the mower the engine turns but does not want to start
if theres a safety mech's on them make sure blades and pto are disengaged, also sometimes you have to depress clutch or have the parking brake set, just like if you are mowing and decide to stop and put it in nuetral if the blades are lowered and pto engaged when you leave the seat the motor will cut off. if that isn't it make sure your spark plug is pushed all the way on.
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades don't engage
Check the drive belt for the blades
Jul 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower starts, but when I let off clutch, it dies.
Grass and debris clogg the switch mechinisms, safety interlocks are sometimes a pain to diagnose but I would first look at the seat interlock, the petal switch and ffinally then the mowing deck.
Dec 24, 2008 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
253 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
