Question about Dometic Rooftop RV Air Conditioner
COMPRESSOR I HAVE A 13,500 DOMETIC ROOF TOP UNIT ON MY RV. THE COMPRESSOR COMES ON EVEN IF THE THERMOSTAT IS IN THE OFF POSITION. IT WILL COME ON AND RUN FOR APPROX 5 MINS. THAN SHUT OFF. IF YOU PUT THE THERMOSTAT ON COOL AND LOWER IT BELOW ROOM TEMP. IT WORKS FINE.
  • bowerstravel May 24, 2009
    With the thermostat off the compressor will start and run for a few minutes then stop. This cycle continues until the circut breaker is turned off.
  • steve
    steve May 11, 2010
    Disconnect the thermostat from the unit. If it continues to do this the problem is isolated to a control inside the unit or a shorted thermostat wire.
    If it stops doing this the problem is the thermostat.
  • 332 Answers
Thermostat is bad
Replace it
Posted on Mar 06, 2010
    Habit-Forming:
  • 62 Answers
Change out the tstat
Posted on Jul 25, 2009
2014 Dometic Brisk II 15,000 unit won't cool below 88 degrees
Check the unit to see if the outdoor fan and compressor are coming on. If not, check to see if power is reaching the contactor, both the high power contacts and the low voltage solenoid. Some contactors can be manually actuated, and a quick press (with a NON CONDUCTIVE ITEM) can show you if the contactor is engaging. If the solenoid is not working, check the wiring of your thermostat. When set to cool mode, there should be voltage on the solenoid of the primary contactor, sending power to the outdoor fan motor and compressor.
If the outdoor fan and compressor engage normally, then make certain the coils are free of debris and other blockages. If air flows freely and the compressor is running, feel the tubing for temperature changes. One side should grow cooler and the other warmer.
If the compressor runs but there is no temperature change, take your unit to a certified technician to check for leaks and system pressures. Roof top units typically use R22 refrigerant not R134a automotive refrigerant, which require EPA certification for purchase and dispensing.
Jun 25, 2014 | Dometic Rooftop RV Air Conditioner
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
I''ve been working on this thing for three weeks now. It is a Dometic Duo Therm model 57915.531 roof top ac on my rv. It will not run. This is what i have done so far: replaced the thermostat, there is...
check the compressor winding resistance from common to start
start to run
run to common
the two lowest should equil the highest
also check shorted to ground
check the capacitors the go bad a lot
May 16, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
277 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
