Question about Bose Wave Music System CD Shelf System
Two cd's stuck in player
A cd was stuck in my bose player, then, forgotten about...now there are two disks stuck in the player. Any way to take the unit apart without destroying it?
Easy fix, just take apart your unit, it is very simple if you have taken anything apart before. Once you get the screws out of the casing and you take the top off the main thing will be taking the top off the cd drive. Hopefully you will not have bent arms from the jam on your cd drive like I did. Because now I have to either get a new drive or send it to Bose for a complete refurb which is only 100 dollars and for what they offer its a great price! I could fix it myself but I cant find the drive anywhere and Bose don't sale internal parts! Anyway once its taken apart remove cd's carefully and reasemble. Easy as that unless you encounter the same problem I did! Good Luck!
Posted on May 30, 2009
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
A CD is stuck in my bose system How do I get it out?
From an other web site
PART I
PART II
Oct 09, 2014 | Bose & Wave& Music System
Bose system plays disk one beautifully,but when changing to disk 2 it says reading disk and then "disk error"....difficult to remove disk...
hi,
There is some problem with the timing of the changer mechanisum of the player. As it is very complicated mechanisum you should need a good reparing experence to rectify the same.The mechanisum is not properly selecting the disk 2. Try to consult the bose autorised servicing center or any trusted electronics reparing shope near you.
ok
Sep 04, 2011 | Bose Wave music system Multi-CD Changer...
Bose am fm single cd disk player, the problem is with the cd player, it takes the cd and won't eject or play was able to take out the cd with tweezers twice before but just bought a brand knew cd and it ot...
the problem with these machines is very common as they run on the old belt drawn cage over time the belt stretches and can no longer break the clamp holding the disc in place it just keeps slipping. the fix is simple just take the unit apart and replace the small belt they cost around $ 6 the problem is getting the unit apart as they a more tricky than a simple standard dvd player but its worth a shot just remember what goes were.
best of luck to you.
please take the time to rate this repair thank you.
Aug 03, 2010 | Bose 32022 CD Player
Cd stuck in disc two slot, how do I release it?
Yo can try a credit card or something thin with some thin double side tape on it and go fishing, Press on the disk with the card with the tape hopefully it will stick to the disk and it will come out. Have patients and take your time be gentle you'll get it.
Oct 03, 2009 | Bose Audio Players & Recorders
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
Bose 123 Disk Stuck
I obviously have placed a CD upside down in the the DVD player-which I have never had a problem with-ever-but now it will not eject the CD- Help please-Steve
Jul 16, 2008 | Bose 3 2 1 GSX System
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Bose Wave Music System CD Shelf System Logo
    386 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Electro Med Services...
    Ben Armstrong
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
