Question about HP Pavilion dv4000 Notebook
Dark Screen It seems my computer will turn on but I get a blank screen. I've already tried hooking to an external source with no luck. I'm guessing it is the video card? I have a HP Pavilion DV4000. What kind of video card to I need to replace it with? Seems there are PCI, PCI Express and AGP types but I'm not sure what that means. What if it is integrated on the motherboard? Please Help!
    Problem Solver:
  • 6 Answers
The unfortunate answer I believe would be it is impossible to replace the video card. Laptops are built with on-board graphics cards on the motherboard. Unless your computer happens to be the first i've heard of with an expansion slot, you are out of luck....IF that's your computer's problem.. I think you should try a few more things first before you determine that's the issue. Try calling HP. Not sure if their tech support charges for phone calls but they didn't when I worked for them. It's worth a shot. Maybe they'll square you right up. :) Take care.
Posted on May 22, 2009
    Scholar:
  • 148 Answers
The video card in a laptop is a built in device, it isn't replaceable as in the case with PC workstations. Well, anything is replaceable. You would need to replace the motherboard would be my best guess, but that may not be cost effective, depending on the age of your system.
Good luck.
Boots up but black screen
If your laptop screen is not working and is blank, you are out of luck as far as working on your computer. However, while there may be a major problem you need to troubleshoot, there are some easy solutions to keep in mind as well, such as brightness settings and your power source.
1.Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2.Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3.Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4.Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5.Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
Sep 05, 2011 | Sony VAIO VGN-TXN15P/B Notebook
Dell optiplex not booting from xp cd
1. Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2. Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3. Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4. Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5. Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
I hope you find it very helpful. Best regards from fixya
Aug 15, 2011 | Dell OptiPlex SX270 PC Desktop
My acer aspire laptop has crashed---the power light is still on but the screen is black and it doesn't respond to anything I do! I can't even turn it off properly---is there a reset button or...
Aug 15, 2011 | Acer Computers & Internet
Blank screen
Aug 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
HP Pavilion dv7-1129wm blank screen upon booting of machine
Jun 16, 2011 | HP Pavilion dv7-1129wm Notebook
I have a dell inspiron laptop, and a dell monitor hooked up to it, i turn on the monitor and it is very bright for about half a second then it becomes very dark, so dark that it looks like it turned off,...
Does the fault appear on the laptop screen aswell? It appears by your description that the fault is only on the external monitor. If the screen comes on for a moment and then goes blank as described, then this appears to be an invertor fault. It is very common among laptop and tft screens and requires the invertor inside the panel to be replaced / repaired. Simply plug the screen into another computer to confirm.
May 29, 2011 | Rosewill R900J 19" Flat Panel LCD Monitor
How can i fix my laptop black screen? I can hear it coming on, but no image on the screen.
Instructions Things You'll Need:
  • AC adapter
  1. 1 Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
  2. 2 Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
  3. 3 Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
  4. 4 Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
Oct 04, 2010 | Computers & Internet
My screen on toshiba notebook only show blank screen. The screen is not dark but has light . If i hook an external monitor it show on external but not on the laptop. I have replaced LCD screen but still...
How about the LCD inverter? Did you replace the inverter? It is probably not the actual LCD but just the inverter that needs changing. Give it a go, they are inexpensive, try eBay.
Apr 01, 2010 | Toshiba Satellite A135-S2276 Notebook
Black Screen
try hooking up an external video source. Check to see if the computer is actually booting up. if the computer boots up, then the LCD invertor or Backlight of the screen is bad, need to be replaced.
If the computer does not boot up after hooking up an external video source, then most likely your motherboard is bad!
Jun 29, 2008 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
