Question about Gestetner DSm616 Printer
I have an error SC:120 Functional Problem
Hello i have a problem with my Gestetner DSm616 copier doesn't work just show me that SC: 120 Functoinal problem hapend. Help me plz
Error sc120
Posted on Jul 24, 2009
Functional error sc 521
it the charge roller problem
Jun 21, 2014 | Gestetner DSm618d Copier
Error 120 code
To reset the SC code follow these directions:
Resetting Ricoh Savin Lanier Gestetner SC Error Code
Error code 120 is scanner home position sensor problem. If it's a recurring problem, here are some troubleshooting tips:
SOLUTION:
Turn the main switch off and on.
Check the wires between Home Position sensor and the SBU.
Fix scanner board or the SBU .
Check the wires between scanner motor and the scanner I/O board
Fix the scanner motor.
Fix the Home Position sensor.
Fix pulley, timing belt, the scanner wire,
Fix the carriage.
Jun 17, 2014 | Gestetner Office Equipment & Supplies
Nashuatec dsm616 sc 544
more than likely to be paper wrapped round the hot roller - remove the fuser and split it - then clean the thermistors - should sort it
Oct 21, 2013 | Gestetner Office Equipment & Supplies
While trying to print, my Gestetner DSc435 is displaying a functional probelm sc560.
Some expert may give the exact answer but according to my knowledge SC 5XX error code series indicates a problem in fuser or paper feeding sections.
Aug 29, 2011 | Ricoh Aficio 450 Copier
My problem is my photocopy is not working it says functional problem within the copier turn operation switch off then on if the error appears again call services sc 560 i dont have manual what can i do
Hi the error code 560 is for the BCU which is a control board for the machine it is not getting a signal from this unit...try this ...press the yellow clear button then enter 107 then hold down the stop/cancel button till the screen changes select copier sp then 5.mode use the arrows to select 810 sc reset execute this and turn machine off .. wait a few then turn back on, if the error was a slight missread it should work away but if the error comes back you may have to remove the back panel and check the connections mayb replace the board.. good luck A.
Sep 16, 2010 | Gestetner DSc338 Color Copier
Gestetner DSM616 no network config
Sounds like you don't have a print or print/scan option in stalled. All machines come with network port but only works if option is intalled. You can check if you have the option installed, maybe just not activated. At the back just abouve the network port there is a cover that covers 2 sd card slots. If the is no sd card installed you will not be able to print to the machine. If the is a sd card installed contact me again and i will help with activation
Mar 24, 2009 | Gestetner DSm616 Printer
Gestetner DSM616
Turn the machine on, and press clear modes, 1, 0 ,7, and press and hold the clear stop key. It will beep, and a menu will appear. Select copy SP (1), and then select data log (#7) scroll until you get to 7807 (sc/jam counter reset). select it, and press execute. exit all the way out, and recycle the power. If it comes to ready, it should be ok. If it happens again after that, there is a fuser problem of some sort.
Mar 05, 2008 | Gestetner DSm616 Printer
Gestetner DSm616 Printer Logo
530 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
