Question about Samsung WF317AAG Front Load Washer / Dryer
Operating of samsung WF-B1061 washing machine
Whnever l on the machine for operation and pou water immediately the water will be drained off, kindly enlighting me how to operate it since l dont have the manual my child has misplaced it. thanks
HI SIR, I HAVE SAME MODEL (WF-1061) MY QUESTION IS THAT, THERE IS ANY FILTER TO BE CLEAN BY MANUALY,BECOUSE I FEEL BAD SMELL WHEN I OPEN THE FRONT DOOR
Posted on Nov 03, 2011
  • 4 Answers
You can download the manual direct from samsung just go to their site type in your machine and download.
Posted on May 22, 2009
The tank gets full with water
that would be the drain pump .
May 12, 2016 | Washing Machines
Error F-H scrolling?
F/H:
Condition
No water detected entering machine or Pressure switch trip not detected.
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Oct 22, 2007 | Kenmore 44932 Front Load Washer
What will i do my american home washing machine AWF 706WS wont continue to operate to rinse and spin? I dont know how to drain the water
to drain the tub ,just put the drain hose lower than the tub
as for the rest have a technician check the program board
Oct 22, 2015 | Washing Machines
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Start load of wash, starts to spin, no water though, then flashes an F and H, eventually stops and machine starts to beep. I just did wash yesterday and haven't tampered with water levels, so can't quite...
FH means that the machine hasn't detected enough water entering the machine or possibly you have a problem with your pressure switch.
Potential Causes
If there is no water in the unit: • Make sure that both valves at the water source(s) are turned on all the way. • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves • Verify inlet valve operation
If there is water in the unit: • Verify Drain pump operation • Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch • Verify there is not a siphon problem • Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU) • Check all hoses for possible leaks • Verify pressure switch operation • Verify flow meter operation • Verify CCU operation
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Amana washing machine will not spin. It agitates & the water drains out fine.
May be the spinning coil is short circuited kindly replace the motor even if you find the same probelm means then you are suppose to change the operational panel
May 15, 2010 | Washing Machines
I have samsung window AC, Water is not drain from my window ac but i am getting the cooling well .. but water stored inside the machine if it make any problem in future? bottom of the machine have one hole...
If you continue to operate your AC with the drain 'closed up' it will eventually :"run over" and probally into the house.
The drain hole should be open so your 'condensate water' can drain to an outside location.
Water is very bad for AC compressors - your service tech doesn't have a clue as to what he's talking about.
good luck!
Apr 26, 2010 | Heating & Cooling
I overloaded my Ultimate Care II - it filled with water, but then shut off. I took half of the load out and was able to do the whole load. Now I am trying to do another load (much smaller), but it shuts...
The first thing to do is unplufg the unit from the mains power and let it stand for 30 minutes. Then plug it back in and start a program again. If the error persists then it should provide you wit h an error codeand will most likely be a faulty level sensor (which is a pressure sensor) and will need replacing or it will be a faulty controller or faulty wiring (see below).
The roor is most likely being seen as a No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash annd the machine will not operate.
Do the following:
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
  • Make sure thatthe filter, outlet hose and drain pump are clear of debris, obstructions and thoroughly clean.
  • Verify there is not a siphon problem and thatthe outlet hose is at the correct level of 36 or more inches from the ground.
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Oct 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Aug 04, 2008 | LG WM-2277HW Front Load Washer
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Jun 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Samsung WF317AAG Front Load Washer / Dryer Logo
887 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
