Question about Bosch Dishwashers
Dishwasher not heating water nor pushing water through rota arms
SPS5462GB/19 Bosch Diswasher is not heating water as it enters nor is it pushing water through rotating arms during wash cycle. Any ideas as to what might be wrong before I dismantle it and think about repair vs. replace?
  • 209 Answers
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Posted on Sep 16, 2007
applianceboy
  • 77 Answers
SOURCE: dishwasher
if no water is coming into the machine at all it is a problem with the water valve, not your spray arms. as far as the spray arm goes I need the manufacture and model number to explain what to do.
Posted on Sep 25, 2007
SOURCE: Bosch diswasher
I had this problem for years, tried everyone's suggestions with no luck. Finally, it occurred to me the the best smell killer is ammonia. I poured about a half cup into the bottom of the empty dishwasher, ran a short cycle and there is absolutely no smell. I think I will do this regularly as needed and sure will not wait until I'm gaggin from that smell. It sure seems common to this brand and the Bosch people will not acknowledge it at all!!
Posted on Oct 01, 2007
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
SOURCE: Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
Posted on Jun 10, 2008
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
2 MONTH OLD bosch DISWASHER. WATER WILL COME OUT BUT TOP SPRAYER ARM WONT SPIN??? LEAVING DISHES ON TOP DIRTY??? LOTS OF WATER PRESSURE THATS NOT THE PROBLEM HELP!!!!!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 31, 2011 | Dishwashers
Our GE diswasher is leaving a white film on all the dishes. We are running it on normal wash and heated dry. Can you put vinegar in the dishwasher to clean it out?
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film:
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning your dishwasher unit by using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic. It is the top formula.
Feb 05, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Water enters the diswasher ok, but does not spray.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
Nov 04, 2010 | LG LDF6920 24 in. Built-in Dishwasher
Bosch SHU5315UC dishwasher doesn't end cycle
make sure 120 degree water enters the diswasher
Feb 08, 2010 | Bosch SHU5316UC Dishwasher
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
Heating Element
Filter/Drain Grate
  • filter
  • . Detergent or Detergent Cup
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    BOSCH SPS5462GB/19 No water seems to be entering. Programmer switch moves to first position then cuts out. Have checked inlet water filter is clear. ??
    Found the problem after stripping down around the main pump area.
    The air pipe connected to the pressure switch on the front right hand side is connected to a small plastic box which in turn is connected to the flow pipe that fills the machine,and the box was completely blocked with slug which stopped the pressure switch from operating and so prevented the water input solenoid from opening. Hence no water would come into the machine
    Jul 13, 2008 | Dishwashers
    Dishwasher runs but does not clean
    Try using a cycle that doesn't heat the water. (Quick cycle?) Using high heat rinse or sanitize will stop the timer while it heats the water. The sensor may be bad.
    Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
    Baumatic mini4 dishwasher
    My first question - If your dishwasher is still under warranty why you don't ask manufacturer service to take care for it !! Water supply to the diswasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water freely into the tub. Check if water are coming into the tub when the diswasher is off. If this is the situation- Open the valve (very easy to do it)and clean it from scale or other dirt (take care not to lose any part). Be aware you should disconnect the power cable from the machine before doing it !!!!! In most cases it should solve your problem, but if not - you should replace the valve with a new one. Good luck !!
    Jun 10, 2006 | Baumatic 24 in. BFD62 Free-standing...
    Dishwashers Logo
    63 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
