Question about Toshiba e-Studio 350 Copier
Toshiba e studio 350 has a c970 code - Toshiba e-Studio 350 Copier
  • Toshiba Master
  • 653 Answers
C970 indicates charging issue. Need to check the T/S block and main charger for deform/broken wires.
Posted on May 25, 2009
  • saint Mar 13, 2012
    Sir Wing Hoe Chang, copierexpert and I have the same problem, do you have any bench mark regarding the reading of each charges? In what particular part of the T/S block should I go through? PLEASE send me details thanks
  • didi2005 Mar 14, 2012
    U need to have visual check on the t/s block & main charger corona wire, whether it is broken, deform, dirty and etc...
    Problem Solver:
  • 7 Answers
Once i have this problem i changed the drum if you can not solve it by charger
Posted on Sep 17, 2013
  • monzer_hamze
    monzer_hamze Sep 17, 2013
    once i have this problem i changed the drum if you can not solve it by charger
3 Suggested Answers
tonesmaker
  • 60 Answers
SOURCE: Error code C970 on my
Check if the charger wire at the side door is broken or main charger grid is deformed.
& if any foreign matters are on the charger wire or main charger grid.
Posted on Jun 12, 2011
SOURCE: toshiba e-studio 232 code C970
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check the black color plastic piece mounted on the machine frame where the main charger connects. If this part is damaged, the high voltage will arc through which can cause C970. (found in several machines).
Posted on Nov 28, 2012
Toshiba e studio 283 error c970
https://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%20283&code=C970
C970
Description
Process related service call High-voltage transformer abnormality: Leakage of the main charger is detected.
Causes
Remedy
1. Is the main charger installed securely? 2. Check if the spring of high-voltage supply contact point is deformed. 3. Check if the needle electrode is broken or the main charger grid is deformed. 4. Check if any foreign matters is on the needle electrode or the main charger grid. 5. Check if the transfer roller and the separation needle are installed securely. 6. Check if the transfer roller or the separation needle is removed. 7. Check if there is any foreign matter attached on the transfer roller or the separation needle. Toshiba Studio 283 Error Codes
Apr 06, 2018 | Toshiba Office Equipment & Supplies
Resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
Mar 19, 2013 | Toshiba e-Studio 232 Black and White...
My problem toshiba e-s352 Code C970 and print is not ok please sole
C970 is an arc check your bios pin on maincharge as well as the transfer seperation unit its loosing powerto one of the charges
Aug 17, 2011 | Toshiba e-Studio 350 Copier
Error code C970 on my toshiba e-studio 2500c. Sais call for maintanance...Can I clear this or fix this on my own?
Jun 08, 2011 | Toshiba e-Studio 350 Copier
Problem on 350 as C970 Help me
you have to clean the main charge area because the corona have humidity and dust.
Nov 04, 2010 | Toshiba e-Studio 350 Copier
I have problem , My machine is toshiba 350 and proble is C970
it has a problem with the HIGH VOLTS CARD, maybe in the transfer area.
other posible solution it is that in the charge unit need to clean by humid.
How can i fix the error code C970 on my toshiba e-studio 230?
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Nov 01, 2010 | Toshiba e-Studio 350 Copier
I am getting white page when ever i try to print from my Toshiba e-studio 350. Installed drivers 3 times.
There are more solution
1. Primary or main chargers cable must be disconnect.
2. Tranfer charger ......
3. H.B.T. (High Voltage problem)
4. Transfer charger Connector is out of work, that means lickage, broken ...
Cheak this I think Thats the real problem, You can solve that by fixing the TR by any kind of glue, I think u can understand what u have to do so .....
100% confidental and this case You can see the error code C970.
Thanks
Jul 03, 2010 | Toshiba e-Studio 350 Copier
Toshiba e-studio 232 code C970
C970: HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
TOSHIBA E STUDIO 280 CALL FOR SERVICE
First of all check what is sub code with this .if it is not showing code press clear & 8 key at same time .code will bi shown .if no code just reset pm cycle count.MIAN AKHLAQ
Dec 31, 2008 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 350 Copier Logo
732 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
