Water dispenser on kenmore side by side, leaks water intermittently. doesnt do it for a while, then will do it enough to fill a container we put underneath it. the pump isnt running when its leaking.
The problem is most likely at the water inlet valve located at the floor at the back of the refrigerator. These valves have a seal that should close off after use but sometimes stick or get a foreign object in the seat. It is intermittent causing only an occasional leak. Sadly, there is no service to the valve and you can only replace it. Good luck, AJ
