Question about Brother FAX-2920 Plain Paper Laser
Does the Brother Fax2920 store sent documents.
If it does can someone advise me how to remove scanned faxes. I can't seem to find anything that will allow me to purge stored documents
  • john_gratric May 22, 2009
    Many thanks,
    Just to clarify If the remote fax option is set to off then it will not store the faxes after they have been sent
    Excellent thanks for the help
  • 1,959 Answers
Turning off Remote Fax
Options
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select Off.
Press Menu/Set.
3 Press Stop/Exit.
If after doing this, you may get a message "Erase all fax?" with 2 options, 1.YES 2. NO
Simply select YES to erase all Fax stored in memory.
I do hope this fully answers your fax question. Take care!
Greg
Posted on May 22, 2009
  • Greg Margossian
    Greg Margossian May 22, 2009
    That's correct. To begin storing faxes again, repeat the steps above and turn the setting "ON" . Best of luck!
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Thanx,
Mar 22, 2011 | Brother IntelliFax-4100e Fax
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Thick line when sending a fax
Open the document feeder, there should be a narrow, long scan glass underneath. Clean that glass. Sometimes whiteout (liquid paper) or other foriegn matter will stick to the scan glass causing a "shadow" (line) on faxes being sent out. Hope this helps.
Aug 24, 2009 | Brother Office Equipment & Supplies
BLACK LINE 1" THICK ON FAX COPY BEING SENT OUT
I bet your incoming pages are clean right? The Laser is not used for outgoing faxes.
Lift up your document feeder and clean the scanner glass that the documents are scanned across
Feb 24, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Stripe on receiving fax Brother MFC 7820N
I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
Aug 15, 2008 | Brother MFC-7820N Printer
Brother MFC-5840CN unable to scan
From Brother Customer Service email:
You can try the following reset - it will most of the settings back to the default options.
Unplug power cord to the machine.
Press and hold down Menu.
Plug power cord back in.
Let go if menu when fax/scan/copy flash.
You may see either "maintenance" or "machine error xx" on the screen.
Type stop/exit, 9, 1.
The machine should show "param init" or similar to show that the reset is being done.
It will then go back to or machine error.
Type stop/exit, 9, 9.
This should take the machine out of maintenance mode and back to normal.
If the error is still present the machine will require an engineer to resolve the issue.
Jul 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother fax machine 8360p
It seems that someone has sent a large fax that has filled the memory. What they may have done is accidentally programmed one of the buttons to send to #342. This is easily done, if those keys are pressed and then an empty program button is pressed right after. You will have to remove the program from the que 1st of all, then remove the program from the button.
Jun 09, 2008 | Brother Office Equipment & Supplies
Brother FAX-2920 Plain Paper Laser Logo
93 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
