Question about Epson Stylus Pro 9600 InkJet Printer
MAINTENANCE REQ 0002
HOW TO REMOVE MAINTENANCE REQ 0002 FROM EPSON 9600
SOURCE: maintenance request 0002
Epson
Maintenance request 0002What is this mean?
Posted on Jun 26, 2009
SOURCE: Because of power fail during printing my printer
Did you remove and reinsert the cartridges? Perhaps, clean the contacts. This is a cartridge error.
Posted on Sep 02, 2010
Ezrahite
  • 2632 Answers
SOURCE: Epson Pro Stylus 9600 is
Welcome to Fixya.
Your error code req 0040 means the Pump/Cap/Cleaning assembly has reached the end of its life and will soon fail. This is a major replacement part and it is typically more cost effective to replace your printer rather than repair.
You can continue to print, but soon you will experience leaking ink, damaged hardware and poor prints.
Here is the solution for your prob. Turn Off your printer then press the Left, Down arrow and Enter simultaneously then power On the printer. inside initialize the sponge and cleaner then turn Off and On your printer.
You have to replace your pump cap assembly if it is already poor in cleaning otherwise your printhead will suffer.
Thanks for using Fixya.
Posted on Feb 15, 2011
  • 158 Answers
SOURCE: we have an EPSON STYLUS
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Posted on Mar 01, 2011
  • 157 Answers
SOURCE: I am Eric, I have
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Posted on Jun 24, 2011
Maintenance req 0040 on my epson stylus pro 9600 printer
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Aug 09, 2011 | Epson Stylus Pro 9600 InkJet Printer
HI MY NAME IS RALPH I HAVE A PROBLEM WIHT MY PLOTTER EPSON 9600 IN DISPLAY SAY SERVICE REQ 001002D WHAT IS THIS???????
Hi mofeed1400 ,
the message " SERVICE REQ 001002D " simply means that some service is required.
call the service centre for " Epson " in your area and get it serviced.
or take your printer to the store where you bought it along with your receipt and ask them that you printer is in need of service.
i hope this helps.
May 16, 2011 | Office Equipment & Supplies
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
How do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
tomas
how do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
Solve this problem:
Aug 02, 2010 | Epson Stylus Pro 9600 InkJet Printer
Epson
May 19, 2009 | Epson Stylus Pro 7800 InkJet Printer
Service req 10005
Check here -- there are two links depending on printer model they both reference an 10005 error code.
http://www.epson.com/cgi-bin/Store/WideFormat/WideFormatDetail.jsp?BV_UseBVCookie=yes&infoType=Support&oid=-12982&category=Wide+Format+Printers&menuSpec=4583
Dec 08, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson sp9600
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
Sep 21, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
355 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
