Question about Freezers
Freezer wont run
This is a 1992 chest freezer that has given me no problems at all. The other day i went to get something out and it was defrosting. the light in the freezer was working but the compressor was not. i unplugged it then replugged it in. after removing the side panel and replugging it in the compressor sounds like it wants to come on but shortly after plugging it in a small spark comes from box mounted on side of compressor and it shuts down. Is this a presure switch or solinoid that I can replace myself? If so where can it be purchased? Thanks James
    Problem Solver:
  • 12 Answers
LIsten for a "clicking" noise that hums and then clicks. If you hear this the compressor is trying to start and it is what is called cycling on the relay. There is a relay and an overload device connected to the side of the compressor that starts it. The problem may be the relay/overload, or it may be the compressor. The noise will occur then repeat a short time(minutes) later. If you don't hear anything, it could be the cold control where you adjust the temperature. Find the control and with the power off, disconnect the wiring to it and try to figure out which of the wires plugged into it are the power leads.Often there is a ground with a stripe(often green in color) and maybe there is a schematic that will tell you. If you can determine this, jump the wires together using any method that will connect them. I often use a non-vinyl coated paper clip, make sure it is not touching metal and plug it in. If you hear that marvellous sound of power, replace the control. The control lead on chest freezers is uninsulated and is pushed into a hole in the freezer near the control and compressor. It pulls out and you push the new one in(I use some lube). If the relay is the culprit there are aftermarket ones available that have directions and are relatively cheap. Good luck, AJ
Posted on May 22, 2009
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
QWhy won't magic chef 6 cubic chest freeze freeze anything after I defrosted it?
Try plugging something else in the outlet. A lamp would work to make sure you did not trip a circut breaker when you plugged back in after defrost.
Apr 23, 2014 | Magic Chef 5 cu. ft. / 142 liter Chest...
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Mar 28, 2011 | Whirlpool Freezers
I have a Danby DCF520W Chest freezer. the compressor runs and the contents freeze but the outside case stays hot all the time. After a couple of days the freezer shuts down and has to be unplugged before...
your freezer may be overheating due to the defrost for the freezer door, (mullan heater) is staying on. Most likely the door is not sealing properly. Also if it has a power saver switch on the side select it to that.
Dec 03, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer Temp keeps getting too high
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 21, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
My brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Apr 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Deep freezer not getting cold enougg even with temp. all the way
Sounds like a stat problem, is it running all the time or does it shut off, put something warm on the stat if it comes on its the stat
Nov 10, 2008 | Bosch 8.72 cu. ft. / 247 liter Chest...
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
218 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
