Question about GE JSP69 Electric Kitchen Range
Not heating properly
Good morning, I have a GE electric wall oven #JKP13OP4BG, it is not heating up to temperature. The broil element does turn bright red after a few minutes and the bake element turns red but not as bright. Any suggestions thanks Charlotte.
    Problem Solver:
  • 12 Answers
There are two possibilities, both of which I think you will need a technician to diagnose. There is an electronic sensor on the later model ovens that sends info to the Electronic Oven Control (If you have a touch panel yours is electronic), or the older ovens use a hydraulic thermostat. The sensor on the electronic model can mess up temperature or it can be the EOC. On the older models, usually there is only the thermostat where you adjust temperatue that can cause this problem. Because you elements get red, they are OK, your problem is in the regulation of them. good luck, AJ
Posted on May 22, 2009
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Maytag electric wall oven model #CWE4800ACB
Try shutting off the breaker and turning it back on after a few minutes.
Sep 05, 2014 | Ovens
I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
Hello there and than you for choosing Fixya
If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
To test the heating element using a multimeter, follow the steps provided below.
  1. Unplug the oven or turn off the power at the breaker or fuse box.
  2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
  3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
  4. Pull the element part way out to expose the oven's wiring connected the element.
  5. Label the wires and secure them in place so they do not fall back into the cavity.
  6. Disconnect the wires from the element.
  7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
  8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
Jan 26, 2011 | Frigidaire Ovens
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
Stove working, broiler working, oven NOT working .. explain pls.
Assumption: This is an electric oven(?).
You seem to be saying that the bottom heating element in the oven is not coming on.
This can be caused by three possible failures: 1. Thermostat (this is the dial you turn to set the temperature); 2. Selector dial (this is the dial you turn to select the mode (broil, cook, etc); 3. the heating element has failed.
My guess is that the heating element has failed (usually the culprit). It is easy to remove.
1. Unplug all power.
2. Unscrew screws at back holding heating element in.
3. Pull heating element out (it may may electrical connection with a jack built into the wall of the oven cabinet or it may have wires you have to disconnect).
4. If you know how to use an ohmmeter, check the element for continuity. It should have some resistance but not MegaOhms.
5. If you don't know how to check, take it to the parts store and let the counter guy check it for you OR just buy a new one and try it out.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | GE Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
GE Electric wall oven
Not sure I can help you but will certainly try. Certainly sounds like the heating element - if not possibly a blow fuse. If you have a tester as in a light tester or proper electrical tester you should be able to turn the element on and test to see if it is getting power. If it isn't it may well be a fuse in the wiring. A lot of ovens these days do not have fuses and rely on the mains having a Safety Switch. Taking this into account I would say it is the element which you will need to remove so you can obtain a new one. With elements on most ovens you have to remove them from inside the oven and sometimes have to remove the back panelling to get to the wires to disconnect them. When you do make sure the power is turned off. Hope this helps.
Regards
Bryan
May 31, 2008 | GE Profile JTP18 Electric Single Oven
Oven is not heating to correct tempurature
its not the thermostat most of the time you can look at the element and see if its bad un less a wire is burned off behind or has come off behind the wall of the oven where the element is you can turn off the breaker to the oven off remove the two screws pull the element foward remove one of the wires to the element and check it with an ohm meter to make sure its bad and some ovens have a vari broil feature but most times they just run full bozo consult your owners manuel to see about yours if you dont have a manuel can get one here http://www.frigidaire.com/support/manuals.asp
Mar 10, 2008 | Frigidaire FEB27S5A Electric Single Oven
GE JSP69 Electric Kitchen Range Logo
198 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
