Question about Canon Cameras
Cannon PowerShot 75 seems appears to not focus in manual mode. Viewfinder is purple and very blurred. Photo playback works fine. Everything mechanical on the camera seems to be OK.
  • hube814 May 22, 2009
    Ops... in re-reading my post it SHOULD have said the camera appears to not focus in the AUTO mode. What we see in the viewfinder screen is a very blurry purplish image..nothing is recognizable. It just looks to me as if the auto focus isn't working. Sorry for the initial wrong report.
  • 355 Answers
The flash exposure compensation feature varies, depending on what mode you're in. Normally, it works exactly like regular exposure compensation. In manual mode, you can adjust the flash power in three steps: 1/3, 2/3 or full strength. If you've got an external flash attached, you'll have a wider range of control: 1/16 to full strength in 1/3 steps.
The photo effect feature lets you quickly adjust the color and sharpness of a photo. For even more control, you can use the custom effect feature to manually adjust the contrast, sharpness, and saturation. Each of these three options has a low, normal, and high setting. You can use photo effects in any mode, including movie mode.
or you can go to this manual
www.dcresource.com/reviews/canon/powershot_g5-review/
hope this will help
Posted on May 22, 2009
  • Rohit  Asthana
    Rohit Asthana May 22, 2009
    Try your camera settings black and white or sepia take them off.Or just reset all your settings
    leave lens off, put in dust free area.
    it may 'come back' after a few days of being open.
    moisture can cause malfunctions. is sensor clean a liquid? or air?
    air can be driven by a propellant which can cause problems.
    try removing battery if it does not come back, or maybe before.
    good luck, otherwise, time for service'
    may be the problem is the unit ccd ,you need the send to canon is free the repair okay ,only call
I have a Cannon EOS Rebel xsi SLR camera. When I look through the viewfinder the image is blurred. IT worked fine the last time I used it, but this time it is blurred and I haven;t been able to correct...
Two possible situations. It might be that the lens focusing system isn't working. Try focusing by hand (turn the lens manually) If the image moves through a point of sharp focus, then you have a lens or focus motor problem.
More likely, you have improperly adjusted the diopter. There is a small, circular wheel on the right side of the viewfinder, toward the top corner. It is sometimes covered by the rubber viewfinder hood so you might not notice it. This adjusts the diopter correction in the viewfinder and if it's set wrong, nothing will ever look in focus. The pictures would be fine, but since the diopter is a correction for your eyesight, the viewfinder will be out of focus.
Feb 05, 2011 | Canon Cameras
S1 IS faulty autofocus and purple cast Pictures have a purple cast , this is also visible in the display screen and viewfinder. At the same time the focus (manual or auto) does not appear to be working,...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 21, 2009 | Canon PowerShot S1 IS Digital Camera
LCD screen purple and distorted in Shooting mode
There is recall on this model for this problem, Go to Canon USA web site, Look up Service advisory, CCD malfunction N/C to repair.
Feb 24, 2009 | Canon PowerShot A80 Digital Camera
Viewfinder of Sony DSC-H2 does not work anymore
Viewfinder has focus lever at bottom, please adjust viewfinder internal focus as per your eye sight looking on-screen display. Every thing will be fine after that.
Feb 04, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Cannon a410
are you on auto mode or manual? if you are on manual, your settings might be on macro mode. reset it to manual.
Dec 04, 2007 | Canon PowerShot A410 Digital Camera
Color registration
does that appear in all kinds f tapes
Jan 26, 2008 | Canon GL2 Mini DV Digital Camcorder
PowerShot A85 capture fault
Yup, it is a common problem. The shutter is jammed. I bet outside pictures are really overexposed. The horizontal lines are caused by the electronic noise created by the shutter solenoid trying to move the shutter. If the cameraq is no longer under warranty- Sometimes, you can free up the shutter by banging the camera in a hard surface like a desk or table. (Do this carefully, don't get carried away) If this doesn't work, you will need to replace the whole lens unit. this is best if the warranty is still good.
Apr 04, 2007 | Canon PowerShot A85 Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Picture still blurred on record mode
Your problem sounds like a focus problem. Could be that it's on manual focus and you're hitting the sweet spot only in full zoom? From the manual: 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button.  M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus.  Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again. Hope it works out, let us know!
Jun 03, 2006 | Samsung SC-D103 Mini DV Digital Camcorder
Cameras Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
