Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool door is locked and it won't start
My door is locked and the controls appear to work until you hit start.  Nothing.   Please help.  There seemed to be a similar question, but the repairman didn't answer.  He wanted to chat.
  • Anonymous Dec 03, 2007
    my door is locked on my whirlpool duet ht front loading washer. I ran a load and now it won't open. The controls lock is not the problem. and I get no error code. It won't allow any functions. Any suggestions please!!!????
    President:
  • 1,294 Answers
Try "the end of cycle" button for over 5 seconds, pressed down for 5 secs, ie. Then wait for 2 minutes & gently try the door.
Posted on Dec 04, 2007
My whirlpool oven locke with F5 E1 what to do
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks
Oct 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a whirlpool duet HT. The control lock botton is on. So the washer will not start it does nothing. I unpluged it, hold in the unlock door botton nothing works. The door opens and close I just...
Hello Welcome to FixYa here is the answer your searching for..Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked. If this was helpful please rate me Thanks :)
Jun 12, 2011 | Whirlpool Washing Machines
Drivers Door Window/Locks aren't working
driver side lock and window switch... if its all one unit... i had a 95 cherokee laredo that did that... changed the switch and it fixed my problem...
Mar 15, 2009 | 2003 Jeep Grand Cherokee
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Self cleaning F5 error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$TRE
Feb 23, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
None of the Wash Cycles are Working
It's probably the touchpad - commonly used buttons quit working after a while. If not, then it's the electronic control board.
Mar 09, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool duet problem with door lock
I've had this same exact problem and that's why I'm at this site.   I have had success with holding the start button and hitting the door right over the place where the switch is on the other side.  That worked good until today so I've called a service tech to come out later this week.  Give that a try and maybe it will work for you.
Oct 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool RMC275PD microwave won't start
I would first suggest unplugging the oven for a few minutes to give it a reset. On Whirlpool brand microwaves, you will hear a series of beeps when you hit START if one of the following is true: - the control panel is not programmed correctly - the door is not shut - there is a problem with the door latch system - there is a problem with the control panel If you do not have your owner's manual, you can download it here: http://www.whirlpool.com/custserv/literature_search_results.jsp?searchTerm=RMC275PD#literror It doesn't sound like the control panel is locked. When the control panel lock is activated, you will see "Loc" and a lock symbol in the display and only the clock, timer, and oven light will operate. If that does not solve the problem, then you have oneof the other problems as listed above. If you need further help, please reply / add a comment here.
Nov 18, 2006 | Whirlpool RMC275PD Microwave Oven
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
75 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
