Question about Dell Dimension 2400 PC Desktop
In my computer my desktop image is not displaying while i boot it
In my computer my desktop image is not displaying while i start, then i active a desktop image it showing for few minutes but that image also going out from ther so help me cure this problem and also i active for windows genune microsoftware without knowing that also displaying some unwanted messages so how can i remove it from my computer plz help me.
  • anandcom_raj May 22, 2009
    in my computer mi desktop images is not showing
  • 464 Answers
You should have been attacked by virus problem...and you have installed a pirated version of windows i suppose..install an original antivirus software, get your desktop cleaned..this is will be a good solution..feed back pls
Posted on May 22, 2009
Not booting ISO image
An ISO image needs to be burned to disk; you cannot boot from the image itself. A free program that can burn the image to a working file is called CDBurnerXP. It will burn CDs and DVDs.
Apr 21, 2014 | Lenovo ThinkCentre M93p 10AA - Tiny...
Install windows 95 from floppy
Microsoft Windows 95 employs the use of a bootable floppy disk to begin the installation of the Windows 95 operating system or to troubleshoot problems with the system. Microsoft Windows 95 uses the MS-DOS system to boot the computer first and then loads the Windows 95 operating system onto the machine. Windows 95 Boot Disks may be created in one of two ways: The Startup disk may be created from within Windows or a boot disk may be created from a free downloaded boot disk image. After the boot disk is created the disk may be used to boot the computer and install or troubleshoot Windows 95.
Click "Start" and then click "Settings" in Windows 95. Click the "Control Panel" option. Click "Add and Remove Programs." Click "Startup Disk" and then click "Create." Insert the blank floppy disk into the disk drive. Click "OK." The operating system will create the Windows 95 boot disk. Click "OK" when the disk is finished. Create the Windows 95 Boot Disk using Downloaded Boot Disk Image Open a Web browser and navigate to the boot disk image site (See "Below"). http://www.bootdisk.com/bootdisk.htm Download the Windows 95 boot disk image and save the .EXE file to the desktop. Click the .EXE file to unzip the enclosed files. The formatting application will start. Insert the blank floppy disk into the disk drive and click "OK." The Windows 95 boot image will be created on the blank floppy disk. Use the Windows 95 Boot Disk Insert the Windows 95 boot up disk into the computer's floppy disk drive. Power the computer down by clicking "Start" and then clicking "Shutdown." Power on the computer with the Windows 95 boot disk in the floppy disk drive. The computer will boot up into MS-DOS to enable installation or troubleshooting of Windows 95.
Feb 13, 2013 | Dell OptiPlex GX270 PC Desktop
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
When I press the OSD reset button to get the screen to optimize the display, the displayed image moves 3 inches to the right (so I get 3 inches of black screen on the left) and the display looks washed...
Hi Mdamon,
Please follow the below steps to solve your problem :-
Your LCD panel has the settings button which you need to use to adjust your LCD screen to the center and make sure there is no black strip remaining after appropriate settings,
To make things easy for you , click on the below to download the manual directly so that you have a complete idea of the steps that are supposed to be taken for the screen adjustment.
There are many factory settings of different settings that are preset and can be activated using the panel.
Tip :- Try changing the screen resolution via the display properties from your desktop as an incorrect resolution could result in bad images or blurred images.
http://bit.ly/lMjygS
Hope this helps, your feedback would be appreciated.
May 13, 2011 | Envision EN9410 19" Flat Panel LCD Monitor
The web cam does not work at all on either the quick viiew software although we have downloaded the driver it is not found
Activating the webcam
The drivers for the webcam are pre-installed and an HP Webcam 1000 icon displays on the desktop. Double-click on the icon to activate the webcam. The blue light illuminated next to the webcam lens, just above the LCD screen, indicates the webcam is on.
If double-clicking on the icon does not activate the webcam, do the following activities:
Click Start, then right-click on My Computer, and then select Properties.
On the My Computer properties window, click on the Hardware tab, and then click Device Manager.
Click on the plus ( +) sign next to Imaging Devices and locate the webcam item in the device list.
If the webcam is not listed, do the following activities to install the driver using the webcam driver recovery.
Click Start, click All Programs, click PC Help & Tools, and then click HP Application Recovery.
Select Driver installation and click Next.
Select the HP Webcam 1000 driver from the list, and click Install.
If the webcam is listed under Imaging Devices but there is a red X on the icon, the webcam is disabled. See figure below.
Figure 1: Disabled Webcam Icon
To enable the webcam, right-click the HP WebCam 1000 icon and click Enable. The webcam icon should display on the Desktop.
Alternate locations for the webcam icon
If the webcam is installed but the icon is not displayed on the desktop, look for the webcam icon in one of these alternate locations.
Click Start, and click My Computer. The webcam icon should be displayed with the other devices. See figure below.
Click Start, and click Control Panel , and then click Scanners and Cameras. The webcam icon should be displayed with the other devices.
The HP Webcam 1000 does not install a listing under any of the All Programs menu.
Using the Webcam Diagnostic Test
To ensure the webcam is operating, do the following activities:
Right-click on the WebCam icon, and then select Properties.
Click on Test Camera under Diagnostics on the General tab.
The test should only take a few moments, but allow the test to complete operations by itself.
The result of the test, either “passed” or “failed”, will be displayed.
Figure 2: Webcam 1000 Properties Window
Mar 11, 2010 | HP Pavilion dv6000z Notebook
Pc cannot boot only displays a blue screen
hey just follow the link
here you will get
Compaq Professional Workstation XP1000 ROMPaq
http://www.soft32.com/Download/Free/Compaq_Professional_Workstation_XP1000_ROMPaq/4-170232-1.html
Sep 30, 2009 | Computers & Internet
I have an HP Pavilion dv2000 and i dont know how to open webcam.
I have an HP Laptop with the webcam. Here is info on it.
There should be an icon on the desktop that you can double click to activate it. Then if it is activated the blue light will go on next to the webcam. If there is no icon do the following:
If the webcam icon is not on the desktop, click Start , click All Programs , select HP Pavilion Webcam to open the webcam from the Windows Start menu.
    • Select HP Pavilion Webcam Demo for a demonstration of the features.
    • Select HP Pavilion Webcam to open the webcam window and display an image from the webcam
  1. If the webcam icon is not on the desktop or on the Windows Start menu, click Start , and My Computer to open the My Computer window. The webcam should be listed under the Scanner and Cameras heading. Double click on the icon to open the webcam window and display an image from the webcam.
  2. If the webcam icon is not displayed on either the desktop or the My Computer window, or cannot be started from the Windows Start menu, the webcam is either disabled or the drivers are not installed.
Enable the webcam If the webcam icon is not displayed on either the desktop or the My Computer window, or cannot be started from the Windows Start menu, the webcam may be disabled. To enable the webcam, do the following actions.
  1. Click Start , right-click My Computer , and then select Properties .
  2. On the My Computer properties window, click on the Hardware tab, and then click Device Manager .
  3. Click on the plus ( + ) sign next to Imaging Devices and locate the webcam item in the device list.
  4. If the webcam is listed under Imaging Devices but there is a red X on the c00678428.gif icon, the webcam is disabled. To enable the webcam, right-click the HP WebCam 1000 icon and click Enable . The webcam icon should now display on the Desktop or the My Computer window.
  5. If the webcam is not listed in the Device Manager window, you should install the original webcam drivers.
If you need the drivers see below.
  1. Install the original webcam drivers If the webcam is not listed in the Device Manager window, do the following activities to install the original webcam drivers using the HP System Recovery.
    1. Click Start , click All Programs , click System Recovery , and then click Application and Driver Recovery .
    2. On the Application and Driver Recovery window, select Driver installation and click Next .
    3. Select HP Pavilion Webcam from the list, and click Install .
    4. When prompted that the installation is complete, click OK .
    5. Allow the PC to restart and test the operation of the webcam.
    When the webcam is operating, visit to the HP web site to look for and install the latest updated webcam drivers. If the quality of the image is not acceptable, you can perform a functional diagnostic test of the webcam.
Jun 30, 2009 | HP Pavilion dv2000t Notebook
GX520 error
To resolve this issue, consider the following steps:
  1. Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  2. At the DOS command prompt, type in: fdisk
  3. Now, you will be prompted with the following question
    • Do you wish to enlarge large disk support (Y/N) ?
  4. Enter: Y
  5. Now to check for active partition, enter: 2
    Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  6. If there's no active partition set, enter the number of the partition to make active
    Restart your computer and the problem should be resolved.
I hope this is what you are lookin for..I am still tryin to build my profile so ratings especially the good ones really help
Aug 08, 2008 | Dell OptiPlex GX520 PC Desktop
I HAD A POBLEM WITH WINDOWS WHEN I BOOT UP ALL I GET IS MY DESKTOP BACKGROUND NO FILES NO START BAR NO PROGRAMS. I PURCHASED THE MX1 THINKING I COULD PLACE MY HARD DRIVE INSIDE AND ON MY NEW DESKTOP COULD...
Windows includes a feature called Active Desktop. One of the symptoms of Active Desktop is that it can hide all your desktop icons. To disable active desktop, right-click on the desktop, choose Properties, go to the Web tab, and uncheck "Show Web Content on My Active Desktop".
If that does not work right away, try rebooting the PC after making the above changes..
May 29, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
