Question about HP Photosmart C6380 All-In-One InkJet Printer
Installed HP C6380 and lost 2 of my hard drives
I installed my new HP C6380 using a USB cable because I don't presently have WiFi in my house. Shortly after I installed it and started printing, I noticed that my second internal hard drive (300gb) and my external hard drive (100gb) connected through a USB connection stopped responding. I've tried unpluging my printer and running the system without the printer, and the drives still won't respond. It seems too much of a coincidence that both drives would fail just at this time.
  • HP Master
  • 13,433 Answers
Try the drives in another usb port set, for example at the back or the front of the computer in a diffrent set of plugs than where the printer is.
Posted on May 22, 2009
Installing used WD800JD into external disk enclosure
The case must be designed for SATA drives. Once the drive is installed in the case, use a USB cable to connect it to the computer. Connect the power supply to the case and start the computer. There will be a new drive letter present.
Nov 25, 2012 | Western Digital Caviar SE WD800JD SATA...
Had a seagate free agent given as a present but i have lost the manual and don't know how to operate it. how do I transfer files and how do I download them onto another PC ?
Hi vic_barnes,
You don't need the manual to operate the external hard drive , all you need to do is connect the drive via the USB cable and your computer should accept it , and then you would find a removable drive visible in your my computer option.
Then you can open this drive and copy your files to and from it.
Hope this helps ..:)
Sep 03, 2011 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
Hp c6380 scanner issues
Contact HP for Care at 1-800-585-2494.
Jan 19, 2010 | HP Photosmart C6380 All-In-One InkJet...
Pc doesnt detect/read portable HDD, but a USB connection appears on the task bar
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Sep 05, 2009 | Toshiba 120GB USB 2.0 Portable External...
We are having trouble installing our new c6380 printer, we have tried to install it into our new hp computer three times via the usb port, with no success, our screen goes a foggy white, and we can not get...
You need to goto add remove programs and remove anything with c6380. then put the disk in again and reinstall. If that doesn't work remove again but this time after uninstall don't use the disk that came with the printer have the computer wizard search onlin for proper installation...
Nov 17, 2008 | HP Office Equipment & Supplies
Bios not recognizing my new hard drive, have new hard drive cable also.
1) Try upgrading the BIOS software (flash it) according to your BIOS manufacturer.
2) What OS are you using?
3) When you fully format a Hard Drive (of any size) part of it is lost to the formatting process, have you checked if you have another partition on that hard drive?
Greetings,
- CoolDragon )O(
Dec 06, 2007 | Maxtor Hard Drive
HP Photosmart C6380 All-In-One InkJet Printer Logo
97 people viewed this question
Seeker5211
Seeker5211
