Question about Behringer EUROPOWER EP2500 Amplifier
What is a mode switch
When i play my instruments and i stop playing i get a strong bass sound from my speakers but then i switch on the mode switch on at the back of the amplifier then it stop a little
Yamaha psr 1000
Hi
I'm not sure I completely understand your problem but......it sounds like you might be in "Fingered On Bass" mode. This means if you play a chord like F using the notes FAC- if you play them in 2nd inversion (so the order is CFA) the psr-1000 will make the note "C" the bass note. In this mode if you played ACF then "A" would be in the bass part. Change to "Fingered Chord"-this will enable you to play any chord with the tonic (the name of the chord) F whether you play FAC, ACF or CFA in the bass part. I don't have access to a psr-1000 but often with Yamaha instruments this can be changed by pressing and holding the "Auto Accompaniment" button. I hope this helps.
Musicwez
Aug 04, 2013 | Music
One speaker stopped playing bass
Sound like either the crossover or the driver has blown or, if you're lucky there is a loose connection internally if you have only checked external connections.
Jun 01, 2013 | Mackie MR5 MR5 Reference Monitor
It plays for about 30 minutes and then just stops, as if overheating. After a cooldown period, it starts up again for another short period. Suggestions? Any recommended vents I could cut in...
The small Fender products often have a TDA2050 power chip in them. The chip is on a thin aluminum heatsink and is intended for light use. If you try to sound like a bass guitar amp with this, the chip will go into thermal protection mode. Cutting vents will not help very much, and pushing it to these levels will destroy the speaker eventually. If you need more power, buy a bigger amp. This one would be suitable for a 10 foot by 10 foot room.
May 24, 2011 | Fender Musical Instruments Corporation...
Speaker has become crackly, only when i play certain notes though. I tried a different cord and bass and its definitely the amp. I have never turned the volume over three quarters, Should I just switch out...
Before changing the speaker, check for debris or other things in the cabinet or grill that MIGHT be rattling..
Also, plug in an external speaker to the ext jack and see if it is clean.
Aug 18, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
I have a rumble 100 bass amp which used to work fine until now! I've had it about 2 months and have only played it about a dozen times. Today, while practicing with a new band, 90% of volume got lost. Now...
It unfortunately sounds like a blown speaker. Try getting at the speaker and gently moving the cone with your fingers. If you feel a rubbing sensation you will most likely have to consider a new speaker. Make sure you get one with the same impedance (ohms) and the same or better power handling.
Jul 07, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Fuzzy sound when instrument being played
The 1/4" output on your bass needs to be resoldered in 1 or more places. It's very common.
Mar 28, 2009 | Audio Players & Recorders
Noise from speakers when playing basses
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Jul 28, 2008 | Audio Players & Recorders
Low treble
I suspect that the speaker levels need to be set. You connected everything right - many people would not have connected the sats via the bass section (which has their high pass crossover and overload protection). But I am betting the HSU is turned up a bit on the high side.
Try this. Set all speakers to small, set all levels to 0. Play the receiver in stereo all mode. If the bass is strong, you need to turn the HSU down closer to a natural sound. Then use the speaker setup tone and adjust as needed.
May 14, 2008 | Onkyo TX-SR304 Receiver
Behringer EUROPOWER EP2500 Amplifier Logo
51 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
