Question about Wahl 2 Speed Hand Held All Body Massager with Heat
HOW LONG DO i RECHARGE FOR.
I RECHARGED FOR A FEW HOURS AND ONLY GOT A FEW MINUTES TIME FROM IT.
    Problem Solver:
  • 5 Answers
Did you let it fully charge before you started using it? Most companies will tell you with any electrical things you need to fully charge before using. To fully charge it can take any where from 4 to 24 hours. So place it on the charger for a full 24 hours then see how it works. Then if it still doesn't work it may be defected.
~~~Good Luck~~~
Posted on Jun 09, 2009
2010 G37 - battery was dead - jumped it off and drove it for twenty minutes. Next morning it wouldn't start and now it wont stop clicking (like a relay). Any suggestions?
if the battery goes dead or low it must be recharged with a charger, driving the car will not recharge it properly. The alternator is only meant to maintain the battery, not recharge it. Get the battery recharged and verified and then try again.
Mar 02, 2015 | 2010 Infiniti G37 Coupe
I have a nextbook 7 or 8 tablet. it no longer charges in any way, and it gets extremely warm when connected to a charger no mattet how short a time it is plugged in for.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jun 07, 2014 | Tablets & eReaders
My zpad won't hold a charge
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
used up.
Jun 05, 2014 | Tablets & eReaders
Why won't my rechargeable ******** recharge?
The charger or batteries are defective. Batteries can only be recharged a couple of hundred times. If the batteries are several years old, even if they have only been recharged a few times are no good. If the charger is inside the product and it goes bad, time to throw away the product. If the charger is outside the product on the cord, you can purchase a new one.
Jun 02, 2014 | Cell Phones
A/C system cooling deteriorates over time
Had a similar thing happen to me, recharged the system and have not had it happen since, note that you should make sure you get a recharger with a long hose, the recharge port is low behind the radiator. It occurred on mine at the beginning of summer.
Jul 19, 2013 | 2008 Buick Enclave
I have one dell inspiron 1525 model notebook and issue is after 3-4 hours running display goes to hazy as well as ghost immages and after 1 hour rest its working properly but its working properly with...
The CTEK Multi vehicle battery charger can recharge a dead HP pavilion dv6000 battery in 30 minutes, which may be less time than you expect from using the vehicle. Importantly, the charger itself can be completely recharged from a power source for a night, which is ready for use the next morning.
Nov 15, 2010 | Dell Inspiron 1525 Notebook
Hello, I have a question: how many hours do i have to recharge my Philips GoGear SA018 mp3 player? In the guide its written to keep it for 3h and when the light is green it means its recharged,however...
If its new and your having this problem DO NOT hesitate to take it back. However most new gadgets when charging for the first time may require a bit more charging time than stated in the manuals.
If the problem persists take it back.
Aug 12, 2010 | Philips GoGear Clip SA018102S/02 2 GB MP3...
How long will the battery last? Can it be recharged in my car? How long does it take to recharge?
Haier HLT71 portable TV battery is good for about 2 hours.
You can recharge it from your car cigarette lighter jack.
Or from your household 120 VAC wall plug.
It comes with both adaptors you need.
It takes about 8 hours for a full charge.
You can charge the TV while watching it, or you can power it off.
Not sure if it charges faster or the same if you are watching.
If the battery does not give you 2 hours after the first charge, try charging and using it a few more times to bring the battery up to full capacity.
Replacement batteries are available on eBay. Good to have for backup in case of a storm.
Jun 21, 2010 | Haier HLT71 7 in. Portable TV
My Lancer 2002 A/C stop working after a few minutes and gives a hot air then it turns on automaticly and so on Thank you
When was the last time you recharged the system? if it was recently, then it may be over pressurized and it shuts down to avoid damage to the compressor. If you haven't done it in a while, you might need to recharge it.
Jun 08, 2009 | 2002 Mitsubishi Lancer
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
Wahl 2 Speed Hand Held All Body Massager with Heat Logo
184 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
