Question about Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Autofocus
Hi, for some reason, the autofocus doesn't work anymore and when I depress the shutter, there is an SB flashing. how do I reset?
  • Anonymous Jun 05, 2008
    I'm also having problems with the flashing red dot and "SB". The camera will not take a shot while this is happening. According to the manual this means the speed light is recharging, but this happens for every shot, even though the pictures don't require the flash! The only solution I've found to the problem is to manually turn off the flash. I've checked all my user settings, and they don't appear to be the problem.
  • Anonymous Jun 10, 2008
    I have the same problem and tried your suggestion which was to turn off the flash.  However, still looking for a solution to the problem.
You need to fix the flash or get an external flash
Posted on Oct 03, 2008
My flash isn't working on my Coolpix 5700. I'm
Hi.
From what I have heard Nikon has recalled the Coolpix 5700 because of the SB error. It has something to do with a connector coming away from the printed circuit board. I recommend that you get in touch with Nikon and see if they will repair the flash for you. Click on the link below to contact them.
http://www.nikonusa.com/Service-And-Support/index.page
Good luck.
Jun 09, 2011 | Nikon Coolpix 5700 Digital Camera
My shutter release button doesn't work or takes very long and my external autofocus flash doesn't work?
Have you by chance got it wet, salt water? Have it checked by a reputable repair shop, and if it has gotten salt into it, best look for a new unit!
Grit destroys these cameras, get a good dust proof case or bag and avoid sand, water, and dust.
Apr 24, 2010 | Nikon Coolpix 5700 Digital Camera
Flashing SB warning light when trying to take picture
Does the flash pop up? If not, try to pull it up manually. Look at your settings in the menu, maybe reset them.
Jun 27, 2009 | Nikon Coolpix 5700 Digital Camera
When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Dec 17, 2008 | Nikon Coolpix 5400 Digital Camera
Nikon Coolpix 5700
your flash doesnt work to use the camera turn off the flash also you can get an external flash for less than it takes for them to fix it good luck
Sep 24, 2008 | Nikon Coolpix 5700 Digital Camera
Re: nikon 5700 faulty flash
It appears that you have a ccd problem.
That particular model had a ccd problem, whether or not the flash is part of it, I do not know.
Here is the link to FREE REPAIR if the problem is the ccd.
http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html
I have sent some Nikons in for repair, and they have been fixed free. The shipping will cost you to send in.
Aug 24, 2008 | Nikon Coolpix 5700 Digital Camera
I've had this problem and Nikon repaired it twice for me at about Aus$200 each time.
Recently it happened again.
Quite by accident, I found that I could lift the black on-off main switch and that it comes off the camera body quite easily together with the chrome shutter button.
Inside was a little plastic tab with contact points.
Merely blowing off the dust inside and then replacing the shutter button and on-off black ring appear to have solved the problem for me.
However, my viewfinder and lcd were working normally and not black as  lsvettek said.
I did have a problem with the viewfinder and lcd on yet another occasion and this was a recognised fault which Nikon repaired free of charge.
Nov 09, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Digital Camera - SB flashing and cannot take picture
Not to buy a Nikon Coolpix anymore.
This is a very bad camera. I had this same error last year. The camera was sent to Japan once, returned to me and worked for six months.
Now is the same problem: SB light in red doesn't let me take pictures in light conditions when flash is needed.
So, you'd better think in buying a camera, not Nikon, please.
JAMP
Havana, Cuba
Lens
If it is almost new the thing to do is to reurn it to the vendor . Check out the situation with Nikon customer support.
Aug 21, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
296 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
