Question about Belling DB120 Gas Kitchen Range
Dial surrounds broken.cant find replacements.
Dial surrounds made of plastic for belling db120.tried to get replacements but no luck. can any one help on tracing them down.
  • Eily Roe Sep 18, 2012
    Hi did you ever find replacements for the plastic surrounds? - we have the same problem - thanks
  • karl owen
    karl owen Nov 19, 2013
    hi i have the same problem cant find the plastic surrounds if ifind the parts il lt you know
  • 1,305 Answers
Http://www.keepingupappliances.com/acatalog/belling.html
Posted on May 22, 2009
Belling 492 bl short out when oven turned on
Sounds like the oven element is broken, replacement at
http://www.elementreplacement.co.uk/belling-elecr11budget-332-p.asp
Check dimensions with the one shown
Mar 16, 2014 | Belling XOU492 Electric Double Oven
Hi I am the proud owner of an early 1980s G Shock watch, model DW-5700. The plastic cover surrounding the watch body is broken and i require a new one. Any tips would be appreciated! Cheers Mike
The only place to go to get a new replacement is back to Timex. They may not be able to replace it as it is rather old but you never know your luck.
Go to Timex.com and at the bottom of the page is "contact us". Send them your question and hope for a positive reply.
Good luck.
Mar 14, 2011 | Casio Watches
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Packard Bell Easy One Silver monitor problem
Hi there.
You need to be looking at the inverter, this is a very thin circuit board located underneath the screen so you will have to remove the plastic bezel (screen surround) check the connections on that. If the screen is still white look at the inverter itself because there could be a dry joint or the coil has gone, if you are confident with a soldering iron then re-solder all the points on the inverter circuit board and try it again.
Good luck and thanks for using FixYa!!
Mar 11, 2009 | Packard Bell Easy One Silver 2120 Notebook
Power connection broken
Sounds like the DC jack on the motherboard is broken. The jack is very inexpensive, but difficult to replace as it's surface mount soldered to the board and the laptop will have to be disassembled or the plastic case cut/modified to replace the DC jack.
Feb 09, 2009 | Lenovo 3000 N100 Notebook
Speedometer doesn't work in my 98 Mits Galant and only warm air.
Well the speedo problem could well be behind the actual speedo gauge. Theres a long square shapped plastic piece on the end of the cable the fits in to the back of the gauge, as it turns it makes the hand on the dial read the speed, In most cases the plastic bit breaks away from the cable which will make the speedo read zero.You will have to get another speedo cable and replace it the same route as your original one.You have to take off the dash surround to get the gauge cluster out for a start to see if its broken at that end.
Jan 20, 2009 | 1998 Mitsubishi Galant
GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Dec 18, 2007 | GE WBSR3140DW Top Load Washer
Belling DB120 Gas Kitchen Range Logo
122 people viewed this question
Top Belling Kitchen Ranges Experts
paulcarew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
