Question about Refrigerators
The side by side fridge either cools too much (at times freezing the vegetables in the bins) or stops cooling (when it starts getting opened a bit morethan few times a day)
Either my fridge cools too much and vegetables etc. freeze in the bins or it stops cooling, especially when I have some company over and it gets opened a bit more..
  • Anonymous May 23, 2009
    Thanks so much. BTW, where do I find this control? What does it look like?
    Problem Solver:
  • 12 Answers
This sounds like an intermittent bad cold control. If you catch it off and hear nothing running and it is warming up, use the handle of a butter knife and rap the knob of the cold control. If it pops on, you must replace the control. Good luck, AJ
Posted on May 22, 2009
My Kenmore side by side fridge isn't cooling hardly. Feeling the suction and discharge lines I think it's low on freon. How do I charge it?
Well I have to go, so I can't wait for your reply for more info. Basicallty what happened to me was the freezer became very good at freezing. The problem with modern freezer/fridges is that there is only one cooling system, the freezer. The freezer chills the other side to chill the refrigerator. Something was blocking that vent into the fridge side. Turns out it was ice blocking the vent into the refer side. It happens when it is humid and the kids to "shopping" in the fridge and leave the door opened for extended periods of time.
If you are blocked by stuff in your fridge, move it away from the vent. If nothing there, you'll need to get ready for a bit of time. Side-by-side freezer/fridges, typically the freezer is on the left. So, open the fridge, somewhere near the back about 2/3s of the way down, just above the vegetable bin, on the left side. Remove the cover, if something is stuck in there, gently try to remove it. If it is ice, like I had, you should remove your vegetable bin and meat bin and unplug the unit (to prevent shock as water will be everywhere. Be sure that your overflow tray (under the unit) is empty. Next is to make quite a bit of boiling water (I ended up using just over a gallon). If you are at the point where you can't get the cover off, you'll have to use a baster to melt the ice that is holding your vent cover on (that is where I started). Then you can start working on the ice. You need to keep putting water in until you get hot water in the overflow tray. Replace your food and don't slam the fridge control all the way to the coldest setting, you could end up freezing your meat and vegetables.
The repairman came and told us, he could do this for us for $200 or we could do it ourselves. He would have done the exact same thing.
Feb 05, 2014 | Kenmore Refrigerators
Everything is freezing in the vegetable drawer
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
This should help.Thanks.Helpmech.
Oct 31, 2011 | Kenmore Refrigerators
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
What causes ice buildup behind the vegetable bin? The drain tube is open but freezes shut.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Sub-Zero 650 / O Bottom Freezer...
Water is collecting on the left side on shelves and vegetable bin
heatman101
Jul 01, 2011 | Whirlpool Refrigerators
Fridge is not cooling down. Freezer is fine only the fridge. Plus the water dispenser - water is not that cold
These units like most fridge/freezers, actually cool the freezer first, then a damper opens that flows freezer air into the fridge side cooling it. The thermostat/switch controls the freezer, the refrigerator is controlled with a damper. The cold water storage tank is usually hidden in the bottom rear of the fridge, behind the vegetable bins, so if the fridge is not cold the H20 is also warm. I suggest you unplug the fridge, empty the freezer and remove the covers. Your issue could be a simple ice blockage of the air passage, or a stuck or broken damper control. Use Sears parts to look up a exploded view of your fridge. At minimum, you will learn a bit, and if you end up calling a service guy, he will know he cannot fool you and overcharge you.
Jan 08, 2011 | Cuisinart Private Reserve CWC-600 Wine...
I'm having trouble with Maytag model MF12067AEB refrigerator that started about 6 months ago. The vegetables/fruits are freezing in the bins....the repairman has been to my house 3 times....replacing the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Maytag Refrigerators
I have a GE side by side GS25LGM. The fridge side gets too cold that it freezes the vegetables. There is a humidity control on the vegetable bin. It didn't matter if I set it to high or low it still...
try turning down the thermostat for the freezer side some times the controls seem backward. However most fridges are desighned for thwe freezer side with some thought giving to pushing some air to the refrige side. in most cases it easier to start back at medium settingsfor two or three days.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
223 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
