Question about AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400)
Steps tp instal Nvidia 6200 AGP card
I am having a system AthlonXP 2600 with mother board Asus A7V8X-MX with an inbuilt graphics 512mb DDRam. I have now brought a new Nvidia  Gforce6200 LE AGP(256mb). I wish to know what are the procedure to install this new AGP card into this mother board and what are the procedure to disable my existing graphics card( if i have to).
your suggestions will be most appreciated.
  • cool_avm Oct 19, 2007
    But the current graphics is an on board one. where is the option to disable it. or will it be automatically disabled once i install this.
    Thnak you very much 'Gskellig' . i ma going to try it. my main confusion was whether i have to disable my previous one. and i couldn,t find the option for that. Yes i am using Windos Xp But i have also an windows 98 istall along with WIN Xp. though i do not use that. will that cause any problem?
    Problem Solver:
  • 14 Answers
Once you have your computer unplugged and taken apart to the point where you can access the AGP slot, take off the small metal cover on the back of your computer (usually fixed with a single screw). Gently place the Nvidia graphics card into the slot, DO NOT force it in. If it's not going in, make sure all the pins lined up right. Try going in from a different angle if necessary.
If everything goes smoothly, then you're done with the first part.
Now plug everything back in, and turn on your computer. You could try the new graphics card now if you wish, you might get a signal. Although even if you do we're not done yet. If you don't get a signal, just plug it into the old slot, we'll configure it with that one for now.
(For this next part I'm going to assume you're in windows XP)
Once you've booted to your desktop, we'll need to install drivers.
If your GeForce 6200 came with a CD for drivers (which it probably did) put that in now. If not you'll have to search around on google for a bit, (I'd be glad to help you with that as well).
Install any drivers/utilities it recommends. Most default settings should be good. When that's done, turn off your computer, (plug in to your new graphics card if necessary), and see if it works!
When you've booted with your new graphics card, right click on the desktop and click properties, then go to the settings tab.
Change the resolution to what you want, you'll probably want about 1280x1024 (pretty standard these days) unless you have a widescreen monitor, then just move the slider until you find a resolution that looks good on your screen.
Make sure the color quality is 32bit, if it's not, and you can't change it we have a problem.
If you're on a flat panel monitor this is also a good time to use cleartype (windows vista enables it automatically I believe). If you wish to do this, go to the appearance tab, click effects, check the second box down, and change it to "ClearType" you can change it back if you don't like the way it looks.
Tips:
-Unplugging everything except the power grounds the system so it's harder to accidentally shock with your body, just make sure a part of your body is touching the metal case when you're working. Also make sure the computer is OFF. (If you do unplug it, touch a sink or ground yourself another way before working, this discharges your static electricity).
-Windows Update might find all the required drivers for you, if you're having trouble you could just try running that.
-If you're using another operating system besides windows XP, the second half of my tutorial is probably very useless.
-You shouldn't have to disable your other graphics card, in fact if you want you could plug in two monitors into your two graphcis cards, and get them to work simultaneously. One will obviously have better graphics than the other, but hey, two is still better than one, right?
Posted on Oct 19, 2007
  • Conor McBride Oct 19, 2007
    The fact that you have windows 98 installed won't matter to your winXP performance (except you'll have less disk space). But if you try to boot in win98 the graphics card won't have any drivers... (probably won't work).
    You shouldn't disable your other graphics card, leave it enabled in case you ever want to use it.
    HOWEVER... I have seen a few cases where the on-board graphics card doesn't like when you install a new one. It's rare that your computer will have this problem but it's possible. I'll be glad to help if you have any more trouble.
    Scholar:
  • 193 Answers
Nothing u need to open teh cabinet and remove the old one and connect the new one>and turn on pc>and if u have a cd with the agp card then run that>and it will automatically installed
Vga card
Look for a AGP x8 graphics card with 512mb memory. Or more.
Jun 18, 2013 | ASUS P4VP-MX Motherboard
Geforce 6200 compatible with asus p4s533 mx?
Hello here is some info about the graphic card:
http://www.nvidia.com/page/geforce6200_agp.html
The driver for xp, can be downloaded here:
http://www.nvidia.com/object/winxp-307.83-whql-driver.html
It haves AGP socket.
Here is the asus homepage:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=15&m=P4S533-MX&os=&hashedid=n/a
Please select your windows system, for downloading the manual.
This mainboard has the 1 x AGP 4X (1.5V only) slot and the graphic card will fit.
Good luck
Mar 19, 2013 | ASUS Computers & Internet
What is a good video card for P4VP-MX mother board? Mainly for smooth video streaming and HD /Blue Ray viewing?
Your motherboard has an an AGP 4x slot.
AGP is an older technology now and has been superseded by PCI-Express graphics.
The best AGP card you can get would be something like this:
http://www.play.com/PC/PCs/4-/5416296/Sapphire-ATI-Radeon-HD-3850-512MB-DDR3-AGP-8X-Graphics-Card/Product.html
It is more than powerful enough for HD video and also has good 3D graphics performance.
Please rate my answer if this helps.
Many thanks,
Chris
Mar 08, 2011 | ASUS P4VP-MX Motherboard
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Which is better, the NVIDIA GeForce4 MX Integrated GPU or the NVIDIA GeForce 6200?
The 6200 has dedicated memory and being a several years more recent design is easily the better of the two.
Oct 04, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Need to increase the ram on the VGA Card
My friend you can add RAM on your VGA by purchasing another Higher Video card  RAM. you can buy 512mb (265 - 512 bit) VGA Card to increase your VGA RAM.
Jun 18, 2009 | ASUS P4P800-X Motherboard
For ASUS A8V-MX Motherboard which graphics card should use
This Motherboard has onboard VGA, but if you want to upgrade the expansion slot is a AGP. so you will have to purchase a AGP VGA card. ATi or Nvidia would be good enough.
Jan 17, 2009 | ASUS A8V-MX Motherboard
Sir i lost my mother board cd so i can't able to install drivers
Not a problem, get the model of your motherboard and google [product name] [OS name] Drivers.
Dec 21, 2008 | VIA Asus P5VDC-MX P4M800 PRO Chipset...
Compatible video cards
This motherboard has an 8x AGP slot. So any 8X AGP graphic cards will suit this mobo. As your local reseller for any 8x AGP based graphic cards from ATI or Nvidia.
Dec 26, 2007 | ASUS P4V8X-MX Motherboard
AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400) Logo
214 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
David
David
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
