Question about Maytag Neptune MAH5500B Front Load Washer
Tricity Bendix AW1001W WILL NOT DRAIN
Hi
My washine machine will not drain.
Do you know what I should do?
Thanks
Lorraine
  • 10,865 Answers
Hi Lorraine - This info should help
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on May 24, 2009
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Why won't my tricity bendix aw1000w drain?
Check the filter and pump for coins, hair grips, screws etc and check the drain hose isn't blocked or kinked
May 09, 2012 | Washing Machines
Tricity bendix aw1001w banged then stopped working i changed the fuse in the plug and moved to another wall socket still not working what will it be please
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 18, 2011 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw1001w has an unknown error code, the led labled end flashing 3 times, any ideas?
It could be one of the E30 codes which would relate to the pressure switch or an earth fault on the heating element there could be a wiring fault or p.c.b. fault check wires off heater at bottom rear of machine,remove back plate 4 screws.Hope this helps.
Good Luck.
May 07, 2010 | Tricity Bendix AW1200 Front Load Washer
Tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Oct 31, 2009 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Mar 18, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix
try opening the small front panel at the bottom right hand side of the machine unscrew the drain guard and check for any blockages
Sep 08, 2008 | Tricity Bendix AW1260W Front Load Washer
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
277 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
