Question about Frigidaire FGS366EC stainless steel Gas Kitchen Range
FGS366EC Gas Slide-in Range-Broiler won't start
We have a FGS366EC Full Gas Slide-in Range that is about a year old.  Recently, the broiler stopped working--it won't light, nor will the coil that glows before the gas flows warm up and turn red.  Frigidaire said that this model has had broiler problems and the model was no longer sold, but I've been unable to find other reports of this problem.  If it's an isolated incident, I'll have my appliance repair person fix it, but if there's a bigger problem, I'd like to know, and frigidaire isn't very helpful on that point.
SOURCE: viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Posted on Dec 10, 2008
freetek
  • 5568 Answers
SOURCE: ours is a xl44 spectra oven will not ignite, broiler sometimes.
Don't you regret now to have shoved your old range out the door? Sorry, it just seems that each time we replace something we end up regretting it.
Your problem is appparently not uncommon and while the model numbers differ, I think you will find the solution in the discussion lined below:
Oven-Broiler ignition problems
Posted on Dec 29, 2008
  • 10865 Answers
SOURCE: no gas getting to oven or broiler stovetop works
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Posted on May 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: Gas broiler won't light
Turn off the gas to the range. Place a amp meter on the wire between the ignitor and the broil gas valve. Turn the control to broil. If the amp draw is between 2.5 and 3.0 the gas valve is the problem. This is for round ignitors. If the ignitor is flat,the amp draw should be 2.8 to 3.7.
The control board is the least likely problem.
Posted on Sep 24, 2009
Testimonial: "Thanks much for the suggestion. I will try it tomorrow and hopefully we can broil again. Good job!"
  • 139 Answers
SOURCE: Hotpoint gas range model RGB7458EAIAD oven won't heat up.
probably a bad thermostat
Posted on Dec 28, 2009
Whirlpool gfg461lvs broiler won't light
Hello. How old is the range? The broiler ignitor might be worn out. The part number you might need is 8054129. The ignitor for the bake is 9758079. I hope this helps you.
Sep 12, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
Bertazzoni gas range - the broiler won't stay ignited
In my case, the igniting wire was too close to another piece of metal. It was igniting upstream from the burner. All I did was push up on the wire, and the broiler started working again!
Jan 16, 2012 | Bertazzoni Kitchen Ranges
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
Oven is slow to start
Dear Friend,
I had the same problem and the first step you should take is to replace the bake ignitor, you most likely to have a weak ignitor. If this doesn´t solve your problem, than your gas valve is failing. Despite the broiler is ok, the gas valve has independent channels for bake and broiler, so it´s possible for one to fail and the other is good. But i believe that changing nthe ignitor will solve it.
Zanes
Dec 03, 2006 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
