Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator seems loose and agitates during the spin cycle
Clothes then become entangles around the agitator
  • 6,784 Answers
HI, the actuator shift device in the transmission is malfunctioning. you will need to replace the transmission soon.
Posted on May 22, 2009
Why does my clothes get stuck around the bottom of my agitator during washing?
the center of your Agitator has a cap or a pull off top inside you should have a Nut, Tighten the nut back down sounds like the plastic Agitator has lifted up and has to be tapped or tighten back down into the Tub.
Mar 15, 2014 | Hotpoint Washing Machines
Basket has become unstable and seems to have come off of the support/stabilizer at the bottom. which causes it to thrash around during spin cycle.
you might have broken the hub. is there little pieces of blackish grey metal on your clothes? if so that could be your problem. the hub is covered by the base of the agitator, remove the agitator by pulling it up (it is very tight) starting to fill the tub with hot water will help to remove it
Feb 06, 2010 | GE WDSR2080D Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
162 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
