Question about Onkyo TX-SR705 Receiver
1080P video via HDMI generates awful interference
Equipment: Onkyo TX-SR705. Panasonic DMP-BD30. Panasonic TC-P50S1 plasma (Just purchased 1 week ago). For 1 year the receiver and the Blu Ray were connected to a Panasonic TH-50PM50U 1080i via HDMI. HD audio & 1080i video ran perfectively. When I purchased the 1080P and connected exactly the same manner all HD audio sources are perfect but the 1080P video has awful interference. The only way I have been able to eliminate the interference is to connect video directly to the plasma and by pass the Onkyo. Onkyo support had me test all HDMI inputs with satellite HD DVR 1080i). No problem. Minute I attempt 1080P video the awful interference starts. Please help!
    President:
  • Onkyo Master
  • 1,114 Answers
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
Posted on May 23, 2009
Onkyo TX-SR606 takes up to 30 minutes to display 1080p
Please don't rate me for this. Onkyo has been having voltage problems with their HDMI boards in several models. Yours is one of them. They first instructed techs to replace some capacitors, then add some capaictors to repair the voltage problems. Now they want us to replace the HDMI boards but I have yet to receive any (on back-order) Sorry for the bad news.
Mar 23, 2010 | Audio Players & Recorders
I have a Panasonic TC-P50S1 Plasma HDTV. I am trying to run my PC into it via DVI to HDMI. It will work, sort of, for a little bit. Then eventually the screen flickers and I lose the picture completely. I...
I BELIEVE THE ISSUE IS THE RESOLUTION THAT THE VIDEO CARD IS SET AT. IF YOU ARE USING THE SAME RESOLUTION AS THE PC, IT WON'T WORK.
TRY SETTING THE VIDEO CARD RESOLUTION AT 1920 X 1080. THIS SHOULD WORK.
ED P
Jan 20, 2010 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Don't want to use receiver to turn Plasma on via Verizon DVR
You can not have a signal from cable/satelite TV when reciever is OFF.The only way is reconnect by using defferent setup configuration to illiminate the receiver.In that case you well see just regular Tv program but you should connect antena to your TV.
Apr 17, 2009 | Onkyo TX-SR705 Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Panasonic blu ray player ?
Hi , i just purchased a blue ray dmp bd30. i wish to use it as to play cds. It is connected to my 2 channel amplifier from the audio outlets, it is connected through the HDMI connection to a Pioneer PDP-428XDA. is it possible to play cds with the plasma turned off? I have folowed the instructions which describes turning off power from the options menu, but the options menu doest display?
Jul 01, 2008 | Panasonic DMP-BD30K Blu-Ray Player
My PS3 is hooked up via HDMI cables to my Onkyo TX-SR 605, then to my 1080p LCD via HDMI. When playing BD movies the TruHD or DTS-HDMA lights don't come on. It is just stuck on Multi channel,Direct or...
YOUR PS3 DOES NOT OUT PUT TRUHD OR DTS HDMA AS STANDARD,YOU CAN GET A UPGRADE ON THE WEB FOR DTS HDMA BUT NOT FOR TRUHD.FOR BETTER SOUND AND PICTURE SELL PS3 AND BUY PANASONIC BD30.
CABLE GUY.
Jun 26, 2008 | Onkyo Audio Players & Recorders
Onkyo TX-SR605 7.1 Channels... Problem
firmware up date go to onkyo homepage
Apr 01, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR705 Receiver Logo
1,096 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
