Question about Acer Aspire 4720 Notebook
Audio jack not playing external speakers/headphone,acer 4720 z
sleepy_user
  • 140 Answers
SOURCE: internal speakers stay on even after headphones are plugged in
You can open up your machine an physicaly disconnect them.
Posted on Jan 23, 2009
  • 59 Answers
SOURCE: Acer Aspire 5720 sound not working
that means the guy or someone who replace the new harddrive didn't to a good job on restiall a new window vista for you, just simply go acer.com and search your model, redownload the sound card driver.
that's it.................
must be sound card driver problem.
Posted on Dec 29, 2009
Jack_Dawson
  • 287 Answers
SOURCE: acer aspire 4720 microphone problem
You can try these steps :
1. Goto Start >> Control Panel >> Sounds >> Recording.
2. Open the 'Microphone Properties' from the list of devices.
3. Change the status of 'Device Usage' to "Use this device (Enable)".
4. Apply settings and close the window.
5. If still the Microphones are not working, try to reinstall the Audio / Sound drivers. Restart your system.
please rate this advice if it helps.....tc! :)
Posted on Jan 14, 2010
yammy_alf
  • 666 Answers
SOURCE: aspire 3680 headphone jack recognizes any
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Posted on Apr 03, 2010
SOURCE: Volume Wheel, Headphone/mike/line in jacks not working
yes, I also fixed by installing the Synaptics touchpad driver.
Posted on Apr 12, 2010
HOW DO I GET SOUND ???
Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
Amazon com AmazonBasics USB Powered Computer Speakers A100 Computers... Amazon com Joylive White 3 5mm In Ear Earpiece Earbud Headphone Earphone...
Jun 27, 2016 | HP Pavilion F1903 19" LCD Monitor
Bauhn faulty audio jack
Hi have you try different headphones? If it still don't fix the problem you need to replace that socket or if your tablet got Bluetooth use this insted. Regards
Dec 26, 2013 | Tablets & eReaders
I am only hearing audio out of my left headphone speaker when plugged into the Tascam US-122. how can I play back my tracks and have the audio fill both speakers?
you might be using a mono output jack or input jack.....check the jack end...1 ring = mono / 2 rings = stereo
make sure your sending a stereo signal in, then check the L/R balance.
Jul 06, 2011 | Tascam US122 Audio/MIDI Interface with...
I cant find the green plug-in my my acer. Where do I plug in my external speakers? Thanks
Headphone/ External Speaker Jack is at the front of Acer Aspire 4720, first from the right besides volume control.
Hope it helps! Good Luck!
CreativeTECH
Feb 07, 2011 | Acer Aspire 4720 Notebook
Plug for pc speakers wire
To use the speakers on the TV when you connect to a PC, get a 3.5 mm M/M audio cable (it may be called a patch cable or audio aux cable) and connect it to the PC audio in port to the left of the composite A/V ports (that's the group with 3 RCA jacks yellow (video)/red(R audio)/white (L audio)). The other end goes into the computer's line out (speaker out) port - which is generally colored green. Otherwise your regular computer speakers will play the audio.
If you want the TV's audio to output to external speakers, use the headphone jack (sometimes labels Phones, again a 3.5 mm plug) or a set of speakers/receiver that takes an optical audio connection. The optical audio jack is between the two coax connectors. Please note using the headphone jack will force the internal speakers off.
I hope this helps.
Aug 31, 2010 | Protron PLTV3250 32 in. LCD Television
My headphone port is not working in my acer aspire5710z laptop. when pin is inserted in the port, still then the inbuilt speakers are playing, not the headphones or external speakers.
Do the following:
Turn off the laptop, unplug power cord and remove the battery.
Put back laptop together, and restart the laptop with headphone jack in. Restart the laptop with headphone in twice.
Third time , while laptop is on, unplug the headphones and restart laptop again.
This will usually fix the headphone problem on Acer laptops.
Sep 10, 2009 | Computers & Internet
Problem in external speaker when connected to acer 5738Z LAPTOP
The audio jack on the laptop is for headphones and most likely cannot it cannot deliver sufficient power to drive unpowered speakers.
Check the audio jack with headphones, if the volume setting is high and you still can't get sounds from the headphone and the mute switch is not selected then the audio amp in the laptop is faulty.
Jul 07, 2009 | Acer Aspire 5920-6727 Notebook
Can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Oct 19, 2008 | Computers & Internet
No sound on headphone jack
plz try by reloading the sound drivers, you can check your head phone jack in another pc
Jul 05, 2008 | Acer Aspire 4720 Notebook
Acer Aspire 4720 Notebook Logo
300 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
