Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Freezer temp is it normal for refrigerator freezer temp to go from 0 or -10 to 20-30 degrees? things in freezer bags start getting crystals forming when temp goes up.
  • 464 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes crystals.it also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
Posted on May 22, 2009
Accidentally left the freezer door open, and ice crystals formed.
You can defrost by turning off the power and leaving the door open, but if it is a frost free model it should gradually rid itself of ice at normal temp settings. This may take several days.
Apr 19, 2015 | Refrigerators
Refrigerator keeps freezing. Temp stays at about 28 degrees. temp control on door (digital) and no matter how much you turn it up, temp stays below 30. Repair man came out and said seal was bad on...
Most likely one or both of the thermistors are bad. Usually pretty easy to find behind a vented cover about 2" X 1" on the side walls of the refrigerator and the top of freezer (if freezer is on the bottom of the unit)
May 31, 2011 | Refrigerators
I have a GE refrigerator model number PSC25SG SA SS which has Problem that in every couple days the freezer and the refrigerator display panels display out of their setting ranges. For example, the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 24, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
Our side by side side by model was purchased in 2002 and has been problem free. Starting about two weeks ago following a party, there has been a continual frost build-up in the freezer. I have removed...
You have a bad freezer door gasket!! it's letting moisture seep into the freezer and once the moisture hits the extream cold it turns to ice crystals.The freezer is designed to get as cold as 0 degrees and the ice cubes stay in cube form as long as the temp is below 32 degrees so the ice cubes didn't make a difference.You can try and CLEAN the contact surfaces of the gasket and freezer real good this usually works,if the gasket is damaged you will need to replace it.
Sep 20, 2009 | Maytag MSD2454G Side by Side Refrigerator
Temp fluctuates in ge profile refrigerator and freezer
Mine is doing the same, but because we were getting frustrated with the interminted noise and motor we kept switching on and off until we realised the frig did not work at all. The key to our problem was, let the frig do its own thing as we realised it was auto defrosting. After 3 days of meddling with this thing, we thought we killed it. Just leaving it on and forgetting about it, it righted itself, and walla it has not missed a beat since. We even blew up another frig in the mean time because of the predicament we thought we were in with all the produce. Good luck and just let the frig do its own thing.
Sep 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge profile french door bottom freezer the freezer temp has been fluctuating form 4 t0 14 degrees have been using turbo cool control to reset drops the temp but by the end of the day its back up
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 28, 2009 | GE Profile PFS22MS Bottom Freezer French...
Freezer temp
No, these fluctuations are a sign of a unstable control unit. test the control unit for its operational value and , replace the thermostats as well.
May 22, 2009 | Kenmore 64722 Top Freezer Refrigerator
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Frozen foods collecting ice crystals in my freezer
Your freezer is getting too warm during the defrost cycle, causing condensation in your veggies and eventually freezer burn. Likely your door seals are leaking as well after 17 years which introduces even more humidity into your freezer, but I'm assuming your talking about sealed bags of veggies? You need to decrease the temp in your freezer. Get a thermometer and make sure you average around zero degrees. The cause? When is the last time you cleaned the coils at the back of the fridge. Or if they are sealed, perhaps you need to have it serviced. You can try moving your freezer setting to a colder setting it may take care of the problem.
May 20, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
158 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
