Question about Logitech X-230 Computer Speakers
Noise coming from speaker with controls
Here's my problem. I've had these speakers for years and have not had a problem with them till recently. The speakers were not in use for about 1 month and while they were not being used they were turned off. I attempted using the speakers last night when I discovered a very loud/annoying sound coming from the right speaker only (the speaker with the controls). The sound almost sounds like the waves of the ocean but it's very loud. Any suggestions on getting this noise/sound to dissolve?
  • gdestiny May 23, 2009
    thanks,
    to clarify, the noise sounds like static and it persists whether the speakers are plugged into the computer or not. In other words, when I turn the speakers on, there's a static noise coming from the right speaker and even when I plug the speakers into the computer; the noise doesn't go away.
    what should i do? i've tried unhooking the speakers from the subwoofer, checking the wiring but have not tried cleaning the speakers. i'll try that.
    what if cleaning the speakers don't help?
  • Rommel Cana
    Rommel Cana May 11, 2010
    try to unplug the speakers from your computer , see if the noise still appears, if still persist you have to look at it whats going on inside it, maybe something is in there which causes it to produce noise, maybe on power supply or the amp inside, a multimeter will do the job detecting where the trouble might be., hope this help, thanks for using fixya!
  • 464 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.since you havent used your speakers for a long time disconnect it and clean it with a cleaning solution.make sure the electrical contact(connection) is tight enough since loose connections will cause such sounds.hope your problem is tackled..have a nice day
Posted on May 22, 2009
My crosley record player comes with built in speaker, but static noises and buzzing noises keeps coming for the speakers, what do I do?
Hi
Quite often this can be due to the volume control rather than the speakers. What sort of noises due you get if you rotate the volume? Do the noises change and is there a particular setting of the control where the noises go away? If so this indicates the volume control. If not it may be the speakers.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 06, 2015 | Crosley Audio Players & Recorders
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
Supertooth disco speaker issue
You need a new battery that supplies the full 2400 mah to unit. Batteries do wear out and the 1800 mah is not going to cut it.
Aug 24, 2017 | Audio Players & Recorders
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Nov 03, 2011 | Logitech Z-4 Computer Speakers
Hello there, I recently purchased a Logitech z-5500 speaker system online, I have plugged all the speakers and set it all up correctly. It makes sound when I pres the "Test" command on the...
verify if the computer has a digital output that matches your speakers (5.1 or 7.1). Also, verify that the cable leading from the PC to the main speaker box is OK. Also, the speakers may come with an installation CD, so you'll need to install the accompanying control application.
Jan 02, 2011 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound out of speakers
Hi there bud , There could be a number of problems as it is a refurbished Speaker Set ,It could be The Subwoofer yes , Have you tried it on other PC's? if it does the same then it is The SPeakers that are faulty :(
Hope this helps
Happy new year :)
Jan 06, 2010 | Logitech Z-5500 Computer Speakers
CRACKING NOISE COMING OUT THE SPEAKERS
Your speakers need replacing or you could turn down the volume till it stops and use it like that if it's not too quiet.
Sep 21, 2009 | Mitsubishi WS-65857 65" Rear Projection...
No Right Front Speaker Output
Swap speakers over...check the balance isn't fully to the other channel...swap left/right phono cables over (if thats how your using it) other than that i would say is broke.
Easy way to check speaker cable/speaker... touch a small battery (like used in a remote) across speaker wires, you will hear and see the speaker cone move.
Aug 07, 2009 | Audio Players & Recorders
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
Speaker issues
This is a duplicate posting, click on the following link to read the active post: http://www.fixya.com/support/t161863-loud_strange_noises
Jul 28, 2007 | Dell 5650 Computer Speakers
Logitech X-230 Computer Speakers Logo
272 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
