Question about Matsunichi i-mat IP3230 Pocket PC
It doesn't charge
My i-mat doesn't charge jomz23
  • 57 Answers
Can be battery or a charger..i would check the battery first..( to know if it still has life...put ur tongue on the battery pins...)
Posted on May 22, 2009
I have a new alt. but it`s not charging all so have on power to instrament panal and no tail lights
Check the belt is not slipping when ticking over and reving...
Check the electrical contacts alternator-battery.
Apr 05, 2016 | 1984-1986 Dodge Conquest Designer Auto Mat...
What does the 12volt AGM button mean on 80amp battery charger by Schumacher
For charging AGM batteries.
AGM (Absorbed glass mat)[edit] AGM batteries differ from flooded lead acid batteries in that the electrolyte is held in the glass mats, as opposed to freely flooding the plates. Very thin glass fibers are woven into a mat to increase surface area enough to hold sufficient electrolyte on the cells for their lifetime.
What are the advantages and disadvantages of Gel, AGM, and Flooded / Wet Lead Acid Deep Cycle Batteries?
Generally, gel and AGM batteries have about 20% less capacity, cost about two times more, and have a shorter cycle life than comparable flooded lead acid batteries. However, Gel and AGM batteries do not need watering, are safer (no acid spilling out), can be placed in a variety of positions, have a slower self-discharge characteristic and are more efficient in charging and discharging than flooded batteries. Gel batteries are more suitable for deep cycling applications whereas AGM batteries are more for light cycling and some engine-starting applications.
Jan 01, 2016 | Jensen Schumacher Sc-600a Speedcharge High...
Where is the reset button.celebrity XL mobility scooter
There is no reset switch. Measure the battery voltage at the charging socket of the scooter, the 2 outside pins.
Aug 27, 2014 | Pride Celebrity Xl 4 Wheel Scooter
05 aztek has the red battery light on but charging at 13.9
the alternator can over charge causing the light to come on. try turning on the heated rear window or something which draws a lot of current it may put the light out .but i would get it chequed out any way
Nov 02, 2013 | Aztek Carpet Floor Mats - Coco Auto Mat...
Why douen't my technics turntable spin?
Take off the rubber mat and see if the belt is off the aluminum platter the record sits on you should be able to see the rubber belt when the mat is removed. If it is not there or broke it will need replaced.
Apr 23, 2013 | Technics SL-BD20D Turntable
Starter no function?
Two things- is your battery charged and functioning? Second, I've had two vehicles that wouldn't start because the driver's floor mat was catching the clutch pedal.
Many cars have a sensor that will not let the car start unless the clutch is pressed all the way to the floor. If the floor mat is holding the pedal up, the car won't start...
Jan 26, 2013 | 1999 Porsche 911 Carrera
How to charge rc ignite helicopter
There is a male jack in the right side bottom of the remote. It looks like the end of a lap top charger only smaller. on the bottom of the heli there is a hole where it fits into. make sure it is in far enough, Not all the way! the heli must be off and the remote must be on. when it is charging the on-off light will blink. when it stops blinking it is charged. if it doesn't blink when you plug it into the heli try pushing the jack in a little farther. mine when in and stoped and i had to push just a little harder to seat it. Good Luck:)
Mar 04, 2012 | Toys
Htc surround phone for att is not charging. used mutliple charges and even tried pluugging in the computer, but it does not work. what else can i try to fix it?
you could have a bad/loose port, which means there is nothing you can do without replacing the phone or trying a charging mat. I would suggest going to a carrier and see if you can borrow a battery to see if the battery is just bad. If that does not work, try to talk to Bestbuy about trying the mat in-store. I assume they have an adapter for this model, as I have seen others talking about it.
Aug 06, 2011 | HTC 7 Surround Cell Phone
Matsunichi i-mat IP3230 Pocket PC Logo
103 people viewed this question
Top Matsunichi Computers & Internet Experts
Roger Currier
Roger Currier
Level 1 Expert
Games Tutorial N...
Games Tutorial N...
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Matsunichi Computer and Internet Expert? Answer questions, earn points and help others
