Question about Toshiba Portege R100 Notebook
Hi I have a Toshiba Portege R100 and everytime I use it after 2 weeks of storage + the batteries are flat.
It has a new Extended Battery fitted and when fully charged last for 6 hours GREAT! but if I only use approx half the battery, it is completley flat next usage.
I have also a TECRA M2 but when I use 50% of the fully charged battery after no usage for approx 2 weeks the battery is still 50% chargeg ...?? Confused
Both are centrino models with max memory fitted.
H E L P !!
Andy
    Brigadier General:
  • 3,917 Answers
If it was working fine before then are many reasons why this could happen
1. Battery is old and is dead
2. Battery not plugged in properly
3. Carbon might have appeared at the ports where the charge passes thru in the laptop
Solution: open the cover where u put the battery, The ports where the battery goes in , try to touch the metal area with any other metal so that if there is any carbon it passes thru to the other metal... and the ports become free
4. Try to do a flee power release
MAke sure battery is fully charged.
Take out the battery from laptop
when the battery is out , press the powe button on laptop for 30 sec and then put the battery in ur lapyop and try to trun it on by pressing the power button firmly.
IT shud work
OR
Try different batteries ( u can borrow )
if it still does not work
They contact laptop vendor , the ports where the power from battery goes in to ur system are faulty
Take it to an authorized service center.
Thank You
Posted on May 22, 2009
Portege R100 (Toshiba). I have not used this laptop in over a year and can not rem the bios password I'd set. Tried all I could think of. Is there any way to reset the password on this?
Hi,yes there is but you'll have to open the system up,if you have no prior I.T expertise I'd suggest you take to a qualified Technician,but if you do here is how:First remove the Battery,then uncouple the system taking of where each of the screws go to then locate the CMOS battery(small battery Lithium Ion mostly in the shape of a cent or smaller),it may be underneath the keyboard or just behind once the external cover is open.unplug it from the system for about an hour or two reconnect it,couple the system and boot,go to Bios,reset Date and Time and save,then exit.
Dec 31, 2010 | Toshiba Portege R100 Tablet PC
Get bluescreen on my R100 everytime I switch the WiFi on
SYSTEM 32 FILE COULD BE MISSING IF YOU HAD INSTALLED ANY NEW DRIVERS, OR SYSTEM FILE HAD BEEN GONE MISSING BY ACCIDENTLY DELETING FILES, TRY TO FIX IT BY CD PROVIDED,..RUNNING IN STARTING AND SELECTING REPAIR, IF DOSNT WORKS, RELOAD THE PROGARM AGAIN..
Oct 13, 2009 | Toshiba Portege R100 Notebook
Toshiba portege r100
Now, that is a tough one. Only way to unlock the hard drive is to have the original password. You will not even be able to access it retrieve any data you want to save.
Thinking you are in the market for a new hard drive and a complete reload of the system.
Mar 16, 2009 | Toshiba Portege R100 Notebook
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
I got the right info about toshiba portege 4000 battery on http://www.adapterlist.com/toshiba/portege-4000.htm toshiba portege 4000 battery but i not sure whether it will fit my notebook or not.
TOSHIBA Portege 4000 Series replacement Notebook Batteries, buy Portege 4000 Series battery and other goods are brand new and one year warranty! ship to most countries http://www.power-tool-battery.com/notebook-battery/toshiba-portege%204000%20series-1001022.htm
Feb 18, 2009 | Toshiba Portege 4000 Notebook
Laptop will not go in BIOS or boot up
We use these and several times I have had to pull the battery, disconnect the power cord and hold the power button for 30 seconds (count slow). After that, it boots fine.
Nov 10, 2008 | Toshiba Portege R100 Tablet PC
On my toshiba R100 / SD card reader doesn't work
this problem bugged me for weeks!! finally figured it out today
download the sd card reader drivers from toshiba (not a 3rd party site) boot into safe mode delete all the sd card reader drivers currently installed install the downloaded driver reboot into normal mode
let the computer go about its business installing the driver, then it should work.
cheers, thomas..
Sep 28, 2008 | Toshiba Portege R100 Notebook
Toshiba without battery
1. If the batteries are dead then there's no way that you can charge them again. You're better off purchasing a new one. You can purchase one online by visiting the ToshibaDirect website or by calling them on 1-800-316-09202.
2. Yes, you can use the power cords to run the computer. Just plug them in using the power cords even with the batteries removed and it should work fine.
3. Yes you can but you might experience some current fluctuations. This is negligible on a CMOS battery though.
Aug 14, 2008 | Toshiba Portege R100 Tablet PC
Can not change Bios Boot Device
remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Jun 14, 2008 | Toshiba Portege R100 Notebook
Toshiba Portege R100 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
