Question about Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive
My system is not stable
Hai, I am having P4 system with samsung IDE hard disk(capacity 40 GB).I have installed Windows XP as OS.When I switch on the computer it gets into windows XP,after a few minute(2 to 3 minute) the system gets restared again and again.What will be the problem? If I change my hard disk it works properly. Pls give a solution for this.
  • 57 Answers
Can be virus...hardware..or o/s issue
  1. Try taking unwanted files or prrgrams
  2. empty the temp folder
  3. Scan using latest anti virus
  4. Defragment
  5. if still same. Try formatting and re-installing the o/s..
  6. if still the same check replacing HDD ...or M/B
Posted on May 22, 2009
Zx-i945lm4 .cannot install windows in 40 GB SATA
set bios for sata to legacy and try again also make sure the drive boot order is correct
May 09, 2010 | Computers & Internet
Can I install a hard drive in an HP Pavilion 6736 which has a capacity greater than 20GB ? If so, is there an upper limit to the capacity..can I install a 120 GB drive?
The size is not an issue with the hardware normally. Usually it has to do with the operating system. If you are running an OS like windows xp you should have no problem.
Just make sure you are using the SAME type interface hard drive. Example PATA Parallel ATA, or Serial ATA (SATA).
May 04, 2010 | HP Pavilion 6736 PC Desktop
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
Hard drive does not hold windows xp
When you install windows and it's shows you 1 or 2 partitions, it's asking you if you want to DELETE partition, - say yes and delete all partitions you have, so when you done deleting all you'll have ~ 79GB of UNPARTITIONED spase. Only then, format as NTFS and install Windows.
Apr 05, 2009 | Fujitsu Computers & Internet
How do i install seagate st3500320as 500 gb sata internal hard disk on a msi 845pe max2 series motherboard. i have installed the hard disk, but it is not detected. presently i have a 40 gb ide hard disk...
ther are jumpers betwwin the data cable and power cable of hard disk...ur 40gb hard disk will be on primary...if u are attaching ur hard on same cable u should put jumper on Secondry
Mar 10, 2009 | MSI : 845PE Max2-FISR...
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
Feb 27, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
HARD DISK CAPACITY PROBLEM
When your hard disk capacity says 320, that does not mean 320 GB fo free space, Total capacity is 320 GB, from this space required for the partition table, boot sector, etc will be taken, Dont worry only the available free space will be shown.
This is not a problem, so dont worry.
Dont forget to rate me fixya
Jan 10, 2008 | Computers & Internet
Windows xp
kgprakash, Did you check your BIOS's Main Page to see if the board is reqognizing the drive correctly? If so did you change from Master setting to Cable Select or vice versa? Some drives don't like to play nice. Have you access to a differnt drive, just to see if XP finds it. If you have SATA or Raid capabilities on the board read the manual this messed me up for awhile (the Asus I use has 6 internal Sata ports and one IDE legacy connector). If you only have IDE, are you in the connector marked or known as IDE0? Just some thoughts.... Pcdok
Oct 21, 2007 | ASUS P5S800-VM Motherboard
Open Questions:
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive Logo
118 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
