Question about Hobart A200 Stand Mixer
A200T HOBART MIXER
NOTHING HAPPENS WHEN PLUGGED IN AND TURNED ON.THE OFF / ON BUTTONS DO NOT SEEM TO ENGAGE ANYTHING.THERE WAS NO ATTEMPTS MADE TO REPAIR,ANY IDEAS
Check to see if the timer is at "0" from the last time it was used.
Posted on Oct 13, 2008
  • 640 Answers
Is there a bowl cage on the mixer?if not bypass the timer and see if it starts.
Posted on Oct 21, 2007
I've broken the agitator shaft pin on my Hobart A200T. I can find replacement pins online, but the local Hobart tech. is MIA. How do you remove the pin? How do you secure the replacement in the...
Drive it out with a punch and hammer. It's best to take the planetary off the machine so you can support the shaft. If not it puts a lot of unnecessary stress on the bearings and other parts.
Jul 08, 2011 | Hobart A200 Stand Mixer
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
A200T Slips in low and medium speed
Planetary gears worn from, #1 changing speeds while unit running, #2 over loading the bowl. batter & icing max 75% bowl capacity, Dough max 65% bowl capacity
Jul 17, 2009 | Hobart A200 Stand Mixer
I need the manual for the Hobart 20 Quart Mixer A200T
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
Mar 05, 2009 | Hobart A200 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
I have a Hobart a200t industrial mixer which isn't running properly. When turned on, it just hums, and the gears don't move. I have been searching online and cannot find a free troubleshooting guide. I...
Hi, it is hard to determine exactly what the problem is without seeing it, however, that mixer usually uses a capacitor to help start the motor, and a switch, or relay, that are in the back of the unit. You probably will not find any troubleshooting guide, Hobart does not give up information easily. You can take it to an electric motor repair shop, and they will easily be able to tell which of those is the problem, and will be reasonable in price. Your other option is to contact Hobart locally for service assistance. Maybe one of the other Hobart techs here can help you out more.
A200t ist gear
This is a lousy diagram for your purpose ...
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Page 14. The spring goes on the right with the hump against the roller.
Mike
Apr 27, 2008 | Hobart A200 Stand Mixer
Mixer has just stopped
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525
Apr 04, 2008 | Hobart A200 Stand Mixer
Hobsrt Mixer problem
Its ok to by pass the timer.You can bypass it and the switch will work.Let me get my service manual and ill post back on how to do it.
Feb 20, 2008 | Hobart A200 Stand Mixer
Hobart A200T General Info / Back cover plate gasket
I'm a service tech for hobart,I'll type your serial number into our database and see what it brings up.The changes that have been made---older units use a mechanical start switch on the motor,the new units use an electronic start switch.the old units center shaft and gears have changed.the older units dont have bowl guards and the new units do.(this is a cage that goes around the bowl).The gasket that your talking about is just that--a thin paper.The paper wears and you get that symptom you describe and its normal.I'll get back to you.
Hobart A200 Stand Mixer Logo
678 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
