Question about HP Pavilion F1703 17" LCD Monitor
HP 17" Pavilion monitor turns on and off continuously.
The monitor has power and doesn't go into sleep mode. It blinks off and on continuously. Any suggestions as to how to resolve the problem?
    Problem Solver:
  • 6 Answers
There are 4 transistors on the power board that are not quit up to par. One of them had died on you. I suggest to replace them all with higher quality transistors. I can't remember the transistors I used to fix the problem but I do remember that I used transistors that could handle higher voltage. Now while you have gone this far there is a bad solder joint on the same board. You should inspect and give it a nice new weld. I hope this helped. Good luck.
Posted on May 22, 2009
  • 52 Answers
Turn off the screen turn off in the power saving options and if that doesn't work then speak to HP, only reason I know is because that's what I had with the exact same monitor!
Monitor goes directly to sleep mode
More likely to be power supply problem due to bad caps, you need to open it up and look for caps with bulging top, post back what you see so we can guide you furhter. See example of failed HP monitors and other due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 06, 2010 | HP Pavilion F1703 17" LCD Monitor
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
I have a HP monitor for 2yrs now. It was working fine until recently I noticed that whenever I boot up the monitor goes into sleep mode and the PC is not coming on. How can I resolve this problem and can...
The problem you are encountering is not your monitor but your computer. There is a problem with your CPU unit. To know this info in true then try this.,remove the connections of the monitor from your own computer then use the monitor to the other computer and see. Hope this could help you determine the real problem.
Oct 26, 2009 | HP Pavilion F1703 17" LCD Monitor
As soon as i turn on my computer the monitor goes into sleep mode
try another cable I have tis problem on mine & I have to do them up solid, also check for bent pins in the cable & bend the back carefully & unplugged.If not you may need to set up the computer to output, try another monitor to rule that out.
Hope this helps!
Sep 22, 2009 | HP Pavilion F1703 17" LCD Monitor
My keyboard mouse and monitor arent working and my computer is in sleep mode, any suggestions please.
Please try pressing the power button once. this should bring it out of sleep mode.
Jun 30, 2009 | HP Pavilion F1703 17" LCD Monitor
Sleep mode
I turned my power off from monitor and tower and turned them back on simutaneously with the F8 key. It worked.
Dec 17, 2007 | HP Pavilion F1703 17" LCD Monitor
My monitor is in sleep mode and I cannot get it out if it.
Sleep Sleep is a mode that the computer enters after being inactive for a set amount of time. Commonly, this mode will turn off a device or set it into a stand-by
Engergy star No data is lost when computer components enter a low-power mode, ... keyboard would get the computer out of this mode. Also see: Power Definitions, Sleep
This should wake your computer, Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Oct 29, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
191 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
