Question about Gateway FPD2185W 21 in. LCD Television
Slow monitor response to input.
I have the Gateway FPD2185W monitor that had the same problems and was fixed with by replacing the 8 capacitors about a year ago. I now have a few other issues with the monitor. It has a single line down the middle of the screen, the auto rotation doesn't work and now the screen has begun to show sings of old age. It is slow to respond to the input of my mouse or keyboard. It acts like it has a problem refreshing the pixels. If I wait about 3 seconds, any input I provide appears as it should. I'm having a slow response issue. I've tested the monitor on 3 different systems, received the same results, so I know it isn't a computer issue.
  • 072500 May 22, 2009
    Also need to inform that the screen has problems displaying scrolling data on websites. There is a slight hint of blue appearing on the screen and typed letters are not as smooth as they should be.
SOURCE: Slow start
(I'm copying a guest's comment above. What Gateway told him does seem to work - although in my case, the monitor was slow to start when plugged directly into the wall, and it was immediately fixed when I plugged it back into a heavy duty power bar.)
hey, I had the same problem. Gateway told me "Plug the monitor power plug directly into a wall electrical outlet
or a different wall outlet by removing any surge suppressors." I did that and it works. It might be a certain kind of power bar they do not like. It worked for me so try that and see if that helps.
Posted on Sep 17, 2008
  • 3 Answers
SOURCE: FPD2185W turn on problem
I had a similar problem... mine would work fine all day. I put it to sleep at night and when I go to wake it back up, it would come on for a second and then back off.
Here's my fix:
BE CAREFUL when popping the case open and unplugging the connectors!
Everything is flimsy and can break easy. TAKE YOUR TIME, and be very gentle.
Ikeep electronic screwdrivers, tweezers and the like for projects likethis. The connectors were a b*tch to get out. They are darn-near microscopic, so take your time and skip that next can of beer... you're going to need patience and concentration to get the little bastards out.
OnceI got inside, I found the capacitors were NOT bulged out the top,leaking, or leaning; however I noticed some of the bottoms on the canswere sticking out further than others.
Hard to say if they are bad, but it won't hurt to replace them since I'm already knee-deep into it.
There are 14 capacitors total that I replaced. You might as well do all of them.
Ok, now time to find the replacement parts:
Thenew capacitors were a bit of work to find. My local Radio Shack andtheir online store didn't have some of them, and the ones they didwasn't rated the same.
The OEM capacitors are rated 105* (1000hrs). There were a Samxon brand. According to some web sites, thesecaps are a general purpose and a lower-quality cap.
The Radio Shack ones are 85*. They would probably work, but who knows for how long.
Ifigure the OEM caps are already made by the lowest bidder, so I betternot take the chance and make it worse! Besides, Rat Shack didn't evenhave all of them.
Here is a list of the caps I found in mymonitor (your monitor may be different and you should check yoursBEFORE you order them)
* ALL OF THESE ARE RADIAL ELECTROLYTIC (aluminum can type), 105 deg. *
QTY. (1) 10 uf, 50V
QTY. (1) 47 uf, 25V
QTY. (2) 68 uf, 450V
QTY. (2) 220 uf, 25V
QTY. (8) 470 uf, 25V
I found all of the parts at Allied Electronics: https://www.alliedelec.com/
Total parts was less than $8.
Allied part #'s:
10uf: 613-0743
47uf: 613-0783
68uf: 613-0312
220uf: 613-0766
470uf: 613-0190
According to their specs, they are good for 2000 hours.
Digikey also had them: http://www.digikey.com
Theirprices were comparable, but I couldn't get all of the same manufacturer(not that it really matters, but I'm picky like that :) )
I took my time and I was up and running in about an hour. Most of the time was spent removing the old caps. They can be a real bear to get out if they have the sticky goo under them.
So far the monitor is running perfectly. Only time will tell if I get the power-up problem again.
Hope this helps.
H.
Posted on Oct 01, 2008
ltfrc
  • 227 Answers
SOURCE: gateway fpd2185w capacitor fix question
Very important, use a pencil iron only, you can destroy the film on the board if you use too much heat. Go for the two bulging ones first. After you remove the capacitors if the holes fill over use a straight pin or similar to open the hole to accept the new part. Also whatch for the polarity on the one you remove, should have a + sign on one side. Make sure the new one goes back in the same way.
Posted on Jan 15, 2009
SOURCE: FPD2185W Gateway Monitor
Mine sometimes had the ghosting problem. Turned out to be the cable connector. Taping the cable to the back of the monitor relieved strain on the connector and eliminated the problem. It also eliminated intermittent flickering.
Posted on Feb 24, 2009
  • 36 Answers
SOURCE: My Gateway FPD2185W monitor goes on for about 1
try replacing the diod located within the group of caps you have already replaced
Posted on Oct 15, 2010
I saw the fix for the blinking power light . I replaced all 8 caps on the power supply board and 2 on the input board. Now the power stays on but no image. The monitor reconises a signal from the computer...
Almost all monitors will accept a 60Hz signal at almost any resolution, however I suggest 1024 X 768 at 60Hz...then you can try higher frequencies such as 75 Hz or more after you have established that the unit is functional.
Feb 11, 2011 | Gateway FPD2185W 21 in. LCD Television
Model 2100 FPD2185W Monitor Will not turn on or seems as if its getting power but screen flickers on and off. Seems as if its in reset mode every 3 seconds. Any help is of utmost wanted.
It's very likely a problem with some of the capacitors in the power supply area. You can search for similar fixes here on this site. I'm ordering parts now for mine. Two of the eight tall/blue capacitors in a bunch have tops that are bulging (but I'll replace all eight since they're cheap). There's a pair of two in the middle of the same board on mine with bulging tops and there are four transistors in that same area that look like they got too hot. Most people seem to be getting away with only replacing the bulged capacitors but here is my total part list from digikey.com:
785-1106-1-ND quantity 2 (the D405-marked transistors) 785-1114-1-ND quantity 2 (the D408-marked transistors) P12389-ND quantity 8 (the 470uF capacitors) P12383-ND quantity 2 (the 220uF capacitors)
The total part list is about $7.50 with another $2.50 or less shipping. It's a pain to take apart, given the small connectors inside. The fix assumes you have soldering skills.
Go with these from digikey versus Radio Shack. They're rated for 220 degrees fahrenheit versus only 85 degrees and they're about a third less cost.
Jan 01, 2011 | Gateway FPD2185W 21 in. LCD Television
I HAVE A Gateway FPD2185W that goes on for a split second then goes black I have already changed the 8 capacitors that i was told to change is there anything else i can do because it still does the same...
make sure there are no briged solder connections. make sure all the inside connectors were properly inserted into the connection on the boards. Check to see if you have the correct input settings by pressing the pushbuttons on the right lower side of the monitor. check all cables or switch to dvi or agp cables.
Nov 26, 2009 | Gateway FPD2185W 21 in. LCD Television
its still ur power chck for swollen fillter capacitors
Oct 17, 2008 | Gateway FPD2185W 21 in. LCD Television
When you say that you replaced "all the capacitors" what are
you referring to? There are 8 identical capacitors in the corner
of the Power Supply/Inverter board that go bad, but there are
also 3 capacitors in the corner of the Main board nearest the
connector that goes to the power supply that can also go bad.
These are associated with the part "U15" nearby, which is the
3.3 Volt voltage regulator for the main board. If these caps go
bad, this regulator can fail to operate, and you will get no display.
Oct 02, 2008 | Gateway FPD2185W 21 in. LCD Television
Trying to fix lcd Gateway Monitor.
There's a couple capacitors you need to replace. On the video board, not the power supply board. There is (3) 470uf16v on the video board. They have to be the smaller ones, you can not use the larger ones (they will not sit flush onto the board) Any questions, e-mail me at Andrew@CreativeAudio.biz
Jul 04, 2008 | Gateway FPD2185W 21 in. LCD Television
Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Jun 05, 2008 | Gateway FPD2185W 21 in. LCD Television
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
513 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
