Question about HP Compaq nx8220 Notebook
DVD Drive reads CD's but wont read any DVD's
The HP COMPAQ NX8220 DVDRW+/- Drive reads CD's but wont read a DVD I've downloaded and installed the new firmware bust still no luck. Running under Windows XP Picks up as DVD-RAM-Drive
    Novelist:
  • 198 Answers
Let me explain some things for you to understand what happened with the dvd drive.
A laptop (or desktop) dvd writter drive is actually build around 2 separate optical systems each specialised to deal with either a cd or a dvd type of disk.
A cd has normally around 650mb - 700mb.
A dvd has normally around 4,3gb - 4,7 gb.
But both disks have the sime size. So the larger capacity disk, the dvd has higher data density as related to the disk surface. Therefore because these disks are being read using laser diodes, each diode must be tuned to a specific frequency for each type of disk. A cd is read/written by a 860 nm diode (infrared) and a dvd is read written by a 630 nm diode (red). These are separate optic subcomponents (by the way, a blue ray disk and reader is called blue ray because of the diode that is used to read them, it's on 437nm and it's emitting blue light).
If your drive will read only cd's and fail to read a dvd then it means that the coresponding optic block for dvd reading has failed. The cd optic system will continue to function as it's not linked to the dvd part.
In this situations there is little to do to save your drive so you should consider the replacement or assistance in a service center for your problem. I'm sorry as we aren't able to fix this without having to dissasemble things and use some service equipment.
Posted on May 22, 2009
  • 57 Answers
If u have tried original good DVD's it should work...or else u may be looking at replacement...
How do I change the boot order ? It some how changed after I formatted the hard drive it turns on but it wont read install cd or flash drive so can any one help me ?
Enter BOS setup
F1 or F10 Enter Setup at the red Compaq logo or blue HP logo
Boot menu Below is a summary of what is contained on the Boot tab of the BIOS Setup:
  • The order for the bottom process; for example: Removable devices, CD ROM, and hard drive.
  • Boot-time Diagnostic screen
strongly urge to update bios too when possible.
Apr 01, 2016 | HP Compaq Cq60-211dx Intel Celeron...
Compaq nx8220
Download the Ultimate Boot Cd
Create cd or usb disk
put in ubcd4win restart computer
press F9 or F10 to get boot device menu
It will run a xp version from from the device you choose
when it installs
go to start
choose Password tools
use the bios one
read properly and follow the instructions
UBCD for Windows
Jul 03, 2014 | HP Compaq 6530b Notebook
Compaq NX8220 laptop reseting
Well it might be a factory default problem with the board, some times when systems are not fixed properly, it come up with such issue. I will advice you take it to service centre near you so as not to void the warranty.
Feb 29, 2012 | HP Compaq nx8220 Notebook
I have a Compaq Presario c700...the DVD RW drive does has stopped reading DVDS. i have done several diagnostics but everytime the result is that the drive is working fine.
Try different DVD's and if you own any, try some DVD Games
if you can buy a CD cleaner as any dust or grime on the lens could stop the DVD drive from reading certain data
the other thing could be that it's reached it's lifespan and it's time to buy a new DVD RW drive, DVD/DVDRW drives are cheap to buy now, so you could probably pick one up for $10 - $20
Mar 28, 2011 | Compaq Computers & Internet
Does not read burnt discs? how do I fix it
It may the problem of lense inside DVDRW which helps to read the cd if the lense get spoilt the DVDRW wont detect burnt discs
Aug 19, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
My PIONEER DVDRW DVR-K15 ATA Device read cd no DVD
have you had any virus infections? I would download malware bytes and rootkit revealer to see if you have any viruses or rootkits you should email me at cringer.smith@gmail.com
and you might have a rootkit that is causing issues with the dvd read/write. otherwise a failing device.
you could also burn puppylinux on a cd, run it and see if you can pop in a dvd and see if it reads the media. if so you are looking at a windows software file or virus issue.
Jun 22, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
Feb 10, 2009 | Pioneer DVR-107D DVD±RW Burner
Compaq Presario V6000: No DVD drive after XP Install
Go To Compaq (HP) Website and download the CDrom Firmware update
Nov 20, 2008 | Computers & Internet
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
HP Compaq nx8220 Notebook Logo
284 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
