Question about Refrigerators
Frezer fluctuating fron 05 to 35 degrees - Refrigerators
  • 6,784 Answers
HI, this is a failing thermostat(cold control). simply replacing the thermostat will fix this issue dealing with the temp fluctuations.
Posted on May 22, 2009
I have Kitchen Aid french door fridge with large temp fluctuation. Please help
Clean your coils first, if they are dirty from dog hair or lint in general it will overheat compressor and cause temps to fluctuate
Oct 17, 2016 | Refrigerators
What are the normal fluctuations of oil temp for a 40 lb Imperial fryer. If I set the temp at 350 the oil heats to 375 and will come back on at 325 to 330. Is this a normal temp swing or bad thermostat?
The temperature fluctuation you describe is quite normal. A 25 degree rise after burner shut off is within factory specs, but you do not want more than a 25 degree shift. If you lower the oil level and look at the bracket that holds the thermostat bulb, make sure there is no build up of carbon or gunk. This can insulate and cause greater fluctuations in temp.
Feb 03, 2015 | Imperial Kitchen Appliances - Others
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
Refrigerator running but not cooling
Is the fan running in the back compressor area?If not check voltage at the fan if there replace fan motor.[Condenser motor] Is the fan running in the frezer compartment if not check for voltage at that motor if voltage there replace motor[Evap motor]
Is their frost on the frezer back wall,in side the frezer compartment? if yes its a defrost problem.Use volt meter to check continuty on heater and term.thermostat [It must becold below 20 degrees to check term thermo.if those 2 ok its defrost timer
Nov 26, 2012 | Refrigerators
Our Kitchenaid KBFA25ERSS01 freezer suddenly does not stay at 0 degrees. Fluctuates between 2 degrees and 12 degrees.
Sounds to me like you could have some serious problems. What you're seeing could be either the result of faulty electronics (i.e. the thermostat) or an even larger problem with the refrigeration system itself.
About the only thing that I could think of that could be repaired by the user would be the door seals if those are leaking. Anything more intensive than that though and your best bet is to contact a service person.
Jul 29, 2009 | KitchenAid Refrigerators
Frezer temp fluctuates from 5-degrees and 30 degrees. I replaced the timer that regulates the defrost cycles but it still same fluctualtion? what can the peoblem be# Amana mod# SZD20KL S/N 8910111816
There can be several reasons for that problem. Condenser fan not working properly, dust and obstruction in ventilation below the refrigerator, defrost element is bad, defrost thermostat defective or low on freon. Check the area under fridge for good air movement and look at the evaporator coils during the time of day the freezer is not cooling its best. If frosted over I think its inside where the element and defrost thermostat. If evaporator coils have some rows on botton frozen over with ice and top is sweaty then its a freon leak. Let me know and make sure you have it unplugged while working on the refrigerator, Thanks, Sea Breeze
May 22, 2009 | Refrigerators
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Dec 31, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
