Hotpoint Aquarius WMA56 Front Load Washer
Problem for Hotpoint Aquarius WMA56 Front Load Washer
Bra wiore inside drum
By davewilsonis on May 22, 2009
Hi Hotpoint Aquarius WML560(G) with a bra wire stuck inside the drum. Managed to get the paddle removed but only succeeded in pushing the wire further in to the machine under the element. Is this where the water drain is and do you think i can leave the wire there? it does not appear to be hindering the drum in any way. Worried about the drain and element though. Any ideas? Thanks.
Best Solution
posted on May 22, 2009
Very Helpful)
juicy_joycie
Rank: Guide
Rating: 100%, 2 votes
HAVE YOU A GOOD BRIGHT TORCH? IF SO I REMOVED MINE WITH A TORCH IN MY TEETH & A SMALL FLAT ENDED SCREWDRIVER, IF YOU CAN SEE IT TURN OFF ALL POWER TO THE MACHINE FIRSTLY THEN USING THE SMALL SCREWDRIVER COAX THE BRA WIRE TOWARDS THE NEAREST HOLE IN YOUR DRUM & THEN FEED IT THROUGH AS BEST AS POSSIBLE & THEN GRAB IT WITH EITHER FINGERS OR PLIERS IF IT IS A STRUGGLE TO PULL IT OUT.
DONT LEAVE IT IN THERE & THEN OPERATE IT AS IT WILL JAM IT & BLOW YOUR EXPENSIVE MOTOR WHICH ARE APPROX £80 OR HIGHER & YOUR PUMP IF IT JAMS IN THE BLADES BEFORE REACHING YOUR FILTER ..
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Hotpoint Aquarius WMA56 Front
Questions and Unsolved Problems for Hotpoint Aquarius WMA56 Front
Do you recommend Hotpoint Aquarius WMA56 Front Load Washer?
Answer
Answer
my hotpoint aquarius WML560 DOOR WONT OPEN EVEN WHEN DOOR RELEASE LIGHT IS ON
Answer
At the end of a cycle all the lights flash (lights from start to end above the start button). this... (More)
Answer
During the wash cycle the display starts flashing and keeps flashing to the end
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
