Question about True T-23DT Bottom Freezer Refrigerator
Iceburg is forming under drain pan in freezer section.
I have replaced the drain tube heater and blown out the drain tube but water is freezing under the evaporator pan over a 3 month period. This is a True 23-DT with the bottom freezer.
  • 1 more comment
  • gmbench400 May 24, 2009
    On the outside bottom of the pan.
  • gmbench400 Jun 02, 2009
    Thank you for the great information.
  • Dennis Boxerman May 11, 2010
    Is water freezing in the pan between the evap bottom and the pan or on the outside, bottom of pan as if it is overflowing?
  • True Master
  • 1,144 Answers
If it takes 3 months for this ice to form, it is most likely not a drain problem.
Let's look at a few things.
The evap could have 2 heaters that are used to clear the frost/ice. One imbedded in the coil and one in the drain pan. The one in the drain pan can be malfunctioning. (Burned out, burnt wire, etc.)
Another issue could be, when it comes out of defrost, the fan delay is not working so it starts as soon as defrost is terminated. This causes the water droplets on the evap to be blown out and onto the back wall or drip down and find it's way to the drain pan bottom.
Over stocking the unit can also cause this. Don't do anything that can restrict air flow around the evap.
Also, be sure the door closes and seals completely around all sides. Most all of these units have some way for the door to close on it's own. Test by opening the door about 45 degrees and then let go. It should close and seal.
Another thing to check is to see if there are the correct amount of defrost cycles. Should be 4 at 30 minutes each as a general rule of thumb. You may have not have enough or possibly the defrost cycles are being terminated too early by the termination control.
You can check to be sure that the end of the drain line is not being blocked by improper installation. You can have this issue and still be able to blow air through. Don't let that fool you. Be sure it lays sideways in the drain pan, if it has one. If not, it may drain freely into a floor drain. If so, check to see if air is being sucked into the drain line while the unit is running. It could **** moisture into the evap area and cause icing.
There a several things to look into. Hope this helps and good luck.
Let me know how you come out on this.
Posted on May 25, 2009
Why would ice form in Built in ge model zis42nyb?
Sounds to me that the condensate drain tube is blocked. Just below the evaporator ZIS42NYB Freezer Section is the drip pan that collect water and drains the water away to the warm side where the condenser evaporates the water back into the air inside your home. Here is a kit designed to prevent water from freezing the drain opening=> WR49X10021 Drain Pan You can also find other information on my website Appliance 911 If you have questions please let me know, Thanks John Tripp
Contact Me Here
Aug 29, 2014 | Refrigerators
Water is leaking inside of the refrigerator on the (if you are looking into the fridge) the left side. I cannot tell where it is coming from - i see no dripping from anywhere but it sits in puddles on the...
I have a Whirlpool Top-mount refrigerator. Whirlpool also manufactures many of the Kenmore refrigerators.
A few weeks ago I noticed a puddle of water on the top right shelf in the refrigerator section. I figured out that it must be the water that forms during the defrost cycle and normally drains down through a tube in the back into an evaporator tray beneath the refrigerator. Something was preventing the water from draining away and instead it was dripping through the overflow holes from the freezer into the refrigerator section.
I emptied the freezer and took off the back panel. It actually wouldn't come off at first because all the water beneath the defrost heater which should have been draining out the drain hole was frozen into one solid block of ice. I used a hair dryer to melt the ice (took a while - be patient) and then took off the panel.
To melt all the rest of the ice in the drain tube I used the hair dryer. To clear out the ice in the drain tube, I used a turkey baster and kept putting down hot water until I heard water making it down to the evaporator tray beneath the refrigerator.
The following mod is "try at your own risk" (I wouldn't do this if you still have warranty coverage - call a tech instead):
I made this modification to prevent the problem from recurring (at least that's the hope): Wrapped a piece of wire (unbent a large paper clip) around the defrost cycle heater and stuck it into the drain hole. The theory is that the wire will heat up every time the defrost cycle runs and will keep the drain hole from freezing shut.
One thing I noticed during this repair concerns the drip pan beneath the defrost heater in the freezer (this is the pan that collects the water that is melted off the coils during defrosting). The drip pan does not seem to be angled properly so that the water will drain normally towards the drain hole. I guess water could remain behind then freeze later. I reported this to Whirlpool.
Mar 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
Recently got called out to an aeg electrolux s range.found evap drain pan in freezer to be iced up.the reported fault was fridge section too warm.found evap fan blade caught in ice, ducted air not getting...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Feb 26, 2010 | Refrigerators
Ice in bottom of upright freezer -- problem with tube position?
Hello, get a short piece of electrical wire and strip the insulation off. put a bend in one end and then hang it over the heater directly above the drain making sure the wire runs into the drain about an inch. the heat from the heater will make sure the drain stays clear. Hope this helps. Mike
Nov 19, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
We inherited a Roper refrigerator with the purchase of our house. There is freezing cold water dripping into the refrigerator section from the freezer section. Often times the water will freeze within the...
Oct 02, 2009 | Refrigerators
My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Aug 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice forming on bottom of freezer section
The freezer should have a drain hole for the defrost water to flow through. This will drain into a pan outside of the freezer cabinet. If this drain tube becomes blocked it will not allow the water to drain out and it will accumulate in the bottom of the freezer section. You will have to verify that the drain is clear through to the drain pan. this can be done carefully with a piece of stiff wire. There should also be some sort of a water trap on the drain tube to prevent air from entering the freezer compartment through the drain tube.
Mar 09, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
True T-23DT Bottom Freezer Refrigerator Logo
134 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
