Question about Dell Latitude C600 Notebook
No bootable devices-strike F1 to retry boot,F2 for setup utillity
Primary hard disk drive 0 not found
secondary hard disk drive 0 not fund
  • jamal190 May 22, 2009
    No bootable device
  • Dell Master
  • 13,433 Answers
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
Posted on May 22, 2009
No bootable device detected
If you strike F1, the system retries as said in the comment. That does'nt solve anything. Rather strike F2 which allows to enter the setup menus of your computer.
In this area you should understand what you are doing. Any update of setupdata may prevent further restart. At least take note of values and changes. You exit setup via a question "update Y/N". Then the computer restarts.
Anyway, in the setup menu you may inspect the devices and see if you the system identifies the disk. If not it may come from a bad connection of hard disk (sata pins, ...) or from low level disk information (format information).
With setup menu you may get in the boot order menu, that allows for the selection of an alternate boot media. You may boot on an installation media, ( install DVD generally, like originall windows install DVD) in order to understand and repair the situation, or from a rescue system like UBCD. You may also try Ubuntu from the CD without installing, just to verify if you may see the disk in the configuration.
Regards
Jul 09, 2014 | HP Computers & Internet
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
My dell 5125 indicates internal hard disk drive not found. it asked me to reseat the drive...than it indicates no bootable devices- i'm strike F1 to retry to boot and F2 for setup utility....nothing...
Try accessing setup utility and verify there if it still recognizes your hard drive, if not then that means your hard drive had crashed. If you have important files on the drive, you can try to recover it by going to a local service provider and have your files recovered, and of course you have to get a new hard drive for your dell.
Sep 13, 2010 | Computers & Internet
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
Can't start windows
The issue you are having is that your computer is not seeing the harddrive or the boot drive. This could be a simple fix from the bios by telling the computer what device it needs to boot from which in this case is your hard drive.
You say that it did work and it was working how long ago was that? It also could be more serious in which you hard drive has crashed or exceeded its MTBF (which means "mean time before failure").
Aug 17, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
The first thing to try is removing and reseating the hard drive. Sometimes the drive just looses it's connection with the motherboard, reseating can resolve that.
If that doesn't work, you can get a 2.5 in USB hard drive enclosure, and see if you can read the drive in another system, and recover you files that way.
Most likely though is the hard drive has failed. If this has occurred, then your options are limited. You can contact a data recovery service, but that is expensive. Http://www.ontrack.com or http://www.drivesavers.com are a couple options. You can contact them and get an estimate of the cost if the other options do not work.
Jun 08, 2008 | Dell Inspiron 6400 Notebook
Dell latitude c640. comes up with error immediately after ram check displays... "primary hard disk drive 0 not found no boot device available - no bootable devices--strike F1 to retry boot, F2...
Seems to be a problem while detecting the hard disk. Please contact customer service if the laptop is in warranty.
Let me know what happens.
Apr 30, 2008 | Computers & Internet
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell Latitude C600 Notebook Logo
2,390 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
