Question about Maytag MDB7100AWB Dishwasher
MAKES HORRIBLE NOISE AT THE START, SEEMS TO WORK OK OTHERWISE
DISHWASHER SEEMS TO WORK BUT MAKE HORRIBLE NOISE AT BEGINNING. I CHECKED ALL THE OBVIOUS THINGS EVEN TOOK OUT BOTTOM PART TO LOOK FOR ANTHING THAT MAY BE STUCK MY FRIEND THINKS IT IS THE TRANSMISSION/MOTOR????
    Scholar:
  • 72 Answers
The first step in a dishwasher's program cycle is activating the drain pump. If there are obstructing objects in the impeller it could make noise, also if the drain pump's bearings/motor is damaged. I don't know what you meant by taking out bottom part, maybe it was the drain pump you checked?
If you didn't this is normally an easily accessible component, when you have it out you can also check that the impeller rotates freely and that it feels and sounds ok in the bearings.
Maybe there is a possibility to attach a sound file here, it would help to diagnose the problem.
Posted on May 22, 2009
My LG 1415T1 sound horrible when running
Normally when one hears a continuous noise throughout the cycle, it is caused by the pump motor bearing having become wet due to a leaking seal. The roller bearing closest to the seal becomes rusted and then creates this awful noise. The pump impeller is a sealed unit so you will have to replace the pump.
Apr 03, 2014 | LG Dishwashers
Dishwasher making strange noise
Check the spray arms for clogs..
Mar 30, 2014 | Dishwashers
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a...
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Oct 15, 2010 | Frigidaire FEX831CS Top Load Stacked...
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Light on.Timer on.No water is coming in.Machine not starting
May be pump problem. Air trapping inside the pump also makes this noise. Add water in the chamber direct manually. Close the door and start the cycle. If the running is Ok, it is air trapping problem. Next wash load it will be alright. Otherwise clean the pump.
May 02, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
When water is pumping out it makes a horrible rattleing noise.
Hi, the problem here is you have a piece of glass or something similar caught in the chopper blade. Pull the lower spray arm out and then remove the screws and the filter and the rest of the assembly inside the dishwasher until you get to the chopper blade. Then remove the debris. Put the dishwasher back together and you should be all set. If you have any other questions please feel free to comment. Mike
Jan 05, 2010 | KitchenAid Dishwashers
Dryer squeaking & Clunking noise
Your particular unit has quite a few things that could be making a real loud noise.....The idler pulley, blower wheel, rear drum rollers, front drum glides. Bottomline is you have to get in there and take the unit apart..vacuuming while there and if the unit is making such a noise, it will be obvious where the problem is.....If I can help further, I am here.......
Eric Campion
Mar 04, 2009 | Dryers
Maytag MDB7100AWB Dishwasher Logo
283 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
