Question about Janome Memory Craft 9000 Computerized Sewing Machine
Top thread breaking during sewing.
Janome 6600p top thread keeps snapping!
    Sergeant:
    Champion:
  • 240 Answers
Your top tension may be too tight or it could be incorrectly threaded. Check threading and ensure you are using a good quality thread. Cheap threads breaks without a reason!
Posted on Jun 11, 2009
    Problem Solver:
  • 9 Answers
Your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
Posted on May 23, 2009
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
Thread keeps breaking
Here is the Manual see page 41 for trouble shooting
Pages 9 to 14 to ensure correct thread procedure
and check pages 17, 18 re correct thread tension
and make sure you have folled maintence guidlines on page 40
S.
Dec 30, 2007 | Janome Memory Craft 3000
Have a Janome 1600P-Top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Apr 21, 2013 | Sewing Machines
Top thread is breaking on Janome 6600P
The needle thread breaks
Jan 16, 2013 | Sewing Machines
I have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
Aug 17, 2012 | Janome Sewing Machines
Janome 2212
try changing needles-flat side to the back of the machine
check for any burrs around the needle plate area
check to make sure the tension is not to tight
check to make sure the bobbin is wound correctly & inserted correctly in the bobbin case
Mar 26, 2012 | Janome 2212 Sewing Machine
Why does my Gutterman thread keep breaking on my 6600? I was told this was a good thread to use a Janome dealer?
Have you got the thread aerial up and using the thread cap on top of the spool of thread to ensure it feeds off smoothly. Also need to look at the thread spool, some of them have a little cut in the top where the thread end is placed to keep neat. If the thread is catching on this, just turn the spool up the other way and use the cap to hold thread away from the edge of the spool.
Gutterman is a good quality thread so you need to check that there isn't something in the thread path catching the thread and affecting the tension which is why it usually breaks. It could be a burr on the bobbin holder, the black plastic tensioning device which sits on a magnet. I have managed to damage 3 of these with my 6600P by trying to stitch too heavy weight seams, the bobbin holder moves and then the needle strikes it, once to the point of piercing right through it!
So have a look in the bobbin area, refer to your manual if you haven't removed the bobbin holder before. There is two little red marks that need to line up when it is in the right location. If you can see damage on the bobbin holder, you could take it out and try to file down the burring with a nail file or very fine grade sandpaper and then put back in again. The needle thread could be catching on a burr as it comes around during the stitch process.
Also, look at the top tension dial, turn it to zero and clean between the discs with the selvage edge of a clean piece of cotton waste. Then turn tension back to 5 and thread up everything and try again.
If you have tried all the above without success then perhaps take it back to the dealer and ask them to test sew it for you and see if they can spot the problem.
Apr 08, 2011 | Janome Memory Craft 9000 Computerized...
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Janome Memory Craft 9000 Computerized Sewing Machine Logo
407 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
